Rev limiter questions
Old Nov 20, 2012 | 09:13 PM
Truck-mutt's Avatar
Truck-mutt
This is my first time on these forums and I just purchased my first diesel and manual vehicle! I've already tuned my 05 F250 with a livewire ts tuner and it runs like a champ but I was concerned about how far I can go with it. When I first purchased the truck i noticed i had no rev limiter and even after tuning it its not stopping where I set it (3600rpms) is there any way to set a limiter on a manual 05 f250? Or am I just missing something?
Old Nov 20, 2012 | 09:21 PM
william_04_x's Avatar
william_04_x
Your rev limiter should be set somewhere around 4100RPM's. 6.0l's spin pretty fast. Above 4500, and a rod will eventually go through the block. Have you asked your tuner about changing the setpoint?
Old Nov 20, 2012 | 09:37 PM
davbeisner's Avatar
davbeisner
Get ready to replace your head bolts with ARP studs and put new head gaskets in there if you're running a tuner! May want to bulletproof it too, while you're at it... The stock 6.0's don't stand up to tunes all that well from what I hear...
Old Nov 20, 2012 | 11:07 PM
smokersteve's Avatar
smokersteve
Reall!? I can take mine up to 4,400 rpms and not worry???
Old Nov 20, 2012 | 11:22 PM
King-bRanch's Avatar
King-bRanch
Subscribing...I too have wondered how fast the Diesel can safely spin
Old Nov 21, 2012 | 05:09 AM
npccpartsman's Avatar
npccpartsman
I wouldn't say don't worry, but mine has seen 4500+ more than a few times on the dyno.
Old Nov 21, 2012 | 05:14 AM
Truck-mutt's Avatar
Truck-mutt
Like I said I set my tuner to stop around 3600 RPMs but the truck will blow past that point. It doesnt seem like anything is limiting it.
Old Nov 21, 2012 | 07:45 AM
Crash16's Avatar
Crash16
Mine was right at 4300 on my 05 w/ the Zf6. I bumped it down a few when I tuned it.
Old Nov 22, 2012 | 12:14 PM
Truck-mutt's Avatar
Truck-mutt
I ended up going stock and still had no limiter. I proceded to put the performance tune back on and still nothing (I set it to 3600 rpms). But the fact that its a manual transmissions has absolutely nothing to do with it right?
Old Nov 22, 2012 | 12:42 PM
Crash16's Avatar
Crash16
May just be the tuner. I'm running an old edge tuner and it will change the rev limiter.
Old Nov 22, 2012 | 12:54 PM
Truck-mutt's Avatar
Truck-mutt
Yeah I might give SCT a jingle then and ask.
9228.bobcat
Nov 30, 2013 08:27 PM
buzter
Modular V10 (6.8l)
Feb 23, 2012 01:30 AM
sick04
Oct 31, 2009 05:31 PM
eric777
Jun 2, 2008 04:05 PM
