un bypassing starter switch
Old Nov 20, 2012 | 10:59 AM
dtgl90vt's Avatar
dtgl90vt
Well I am finally tackling the bypass switch to the starter that the PO installed
But I am stumped, I found the ignition switch (connector) and its just dangling, not bolted or screwed down or anything.
I am looking at the EVTM and it says I am supposed to have a Red / light blue wire feeding the starter relay, which I didn't have but picked up at the JY.
I can't find the R/LB wire in the wiring harness though, I did find it under the hood though, I believe, and when I throw the ignition to the start position I get no voltage in the R/LB wire under the hood, which makes sense cause I cant find it under the dash.
So does anyone know does the R/LB wire start a different color at the ignition switch, it doesn't seem to say so in the EVTM, if not why cant I find it.
Devin
Old Nov 20, 2012 | 01:24 PM
Phy's Avatar
Phy
The EVTM should show what pin it is in the connector on the ignition switch: you should be able to find it (and check it) there...
the gruffalo
Jan 8, 2022 07:38 PM
rollinblacksmoke
Dec 23, 2013 06:11 AM
Woodsman_30350
Jun 6, 2011 12:27 PM
James Campbell
Electrical Systems/Wiring
May 17, 2006 07:06 AM
77fromheaven
May 2, 2002 01:49 PM
