towing a bobcat
Old May 22, 2003 | 10:20 AM
F150daniel's Avatar
F150daniel
towing a bobcat
I going to rent a bobcat soon they weigh about 6,000 lbs and the trailer weighs about 2,000 lbs thats 8,000 lbs total I have a 79 F100 wornout 302 C4 2.75 gears, yah I know but my buddy has a 79 E150 302 C6 3.25 gears and it has a reese hitch, he'll let me use it anytime but it doesn't have insurance he plans on fixing that soon and it has taillight probelms that need to be fixed. witch one?
Old May 22, 2003 | 10:39 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
towing a bobcat
My choice would be the E150 because:
C-6 is stronger then C-4
3.25 axle ratio is better than 2.75
E150 has a shorter distance from rear axle to hitch
E150 has a heavier GVW(springs) than F100
Old May 22, 2003 | 11:00 AM
Colossus's Avatar
Colossus
towing a bobcat
F150 or E150, thats not an easy load to haul at all, so be careful. They're topheavy.
Old May 22, 2003 | 11:25 AM
johnsdiesel's Avatar
johnsdiesel
towing a bobcat
Tow the F150 or E150 with the Bobcat! Just kidding. I think they are both severely underpowered, mostly a result of the gear ratios. How far do you have to travel? If it's not far, use the E150 and be careful. If it's a fair distance, look into borrowing or renting another vehicle.
Old May 22, 2003 | 12:33 PM
F150daniel's Avatar
F150daniel
towing a bobcat
About 15 miles.
Old May 22, 2003 | 01:04 PM
steve83's Avatar
steve83
towing a bobcat
Either should work; just keep it under 40mph.
Old May 22, 2003 | 01:34 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
towing a bobcat
Find out if the equipment rental will deliver the Bobcat for you. Then spend your time enjoying a cup of coffee while the tractor is on it's way to you. Instead of a white knuckle ride you may never be able to forget. If the trailer has a pintle hook with a ball coupler adapter, it could be way over 2,000# anyway. Most of those construction equipment trailers are made for towing behind a dumptruck and they are a lot heavier than a car trailer.
Scott
Old May 22, 2003 | 11:32 PM
Kenworth's Avatar
Kenworth
towing a bobcat
Get the Bobcat delivered its cheaper in the long run and you don't have to worry about trying to pull a trailer with it on it and the rental shop doesn't have to worry either.
A 1/2 ton shouldn't be pulling a Bobcat its minimum 3/4 ton P/U a skid steer is heavy and weighs more than a 1/2 ton P/U truck does.
Old May 22, 2003 | 11:38 PM
Colossus's Avatar
Colossus
towing a bobcat
Yeah, on second thought, get it delivered. We hauled one of those bobcats behind our 250 and that thing had to work.
Old May 23, 2003 | 09:07 PM
FiremanRon's Avatar
FiremanRon
towing a bobcat
I responded to an accident once where a pick-up pulling a bobcat ran into the back of a semi. I don't know if he had trailer brakes, but my guess is not. The trailer was too heavy for the hitch and ripped it off the pick-up. Luckily, only minor injuies.
Old May 25, 2003 | 05:50 PM
Gwilkrrs's Avatar
Gwilkrrs
towing a bobcat
i tow bobcats all the time. both trucks will be working overtime to pull one based on the size of the cat. pay the delivery to be safe.
Old May 26, 2003 | 05:30 PM
flyboy2610's Avatar
flyboy2610
towing a bobcat
Last week for several hours one lane of I-80 through Lincoln was shut down because a guy was towing a Bobcat with a too small pickup. It got away from him and flipped the truck on its side . Totalled the truck and the Bobcat.
Have it delivered.
Old May 26, 2003 | 07:49 PM
F150daniel's Avatar
F150daniel
towing a bobcat
OK OK OK I'll have it delivered.
Pacific81
All Things Towing
18
Jan 25, 2017 10:14 AM
UGA33
6.7L Power Stroke Diesel
Sep 28, 2016 03:34 PM
jbehuniak
13
Feb 21, 2016 07:52 PM
bobcat518
Sep 20, 2015 07:20 AM
bigblue
Jul 11, 2002 09:16 AM
