Granny Tranny Identification
Old Jul 8, 2002 | 09:56 AM
bigblue's Avatar
bigblue
I need to know what transmission I have. It is a 86 F150 with a straight 6 cylinder granny gear four speed. There is a 4x6" access plate on the passenger side. It has a ten spline input shaft. It weighs about 160 lbs. Numbers cast into it are C-13894. There are 2" tall white block letters on the side that read E3TAU. The stick makes two curves coming up through the floor. Can some one tell me what it is? Thanks.
Old Jul 8, 2002 | 12:40 PM
Kenworth's Avatar
Kenworth
If its a cast iron brute and your truck is the year you said it is its probably a T-18 Borgwarner I can't remember if they used the NP-435 in the year of truck yours is. A T-18 tranny is good I have one in my old 1980 F-350 dually LWB flatdeck and I find it shifts nicer than the old NP435s the gears seem tobe more evenly stepped but the T-18s first gear isn't as low as the 435 the only real drawback. The plate on the side of the transmission that is held by 6 bolts is where you bolt on a PTO.
Old Jul 8, 2002 | 04:04 PM
brown 4x4's Avatar
brown 4x4
[updated:LAST EDITED ON 08-Jul-02 AT 05:09 PM (EST)]Yep, the NP435, T-18, and T-19 were offered in '86. NP435 has a low of 6.69 while the T-18's is 6.32. The T-19's is 5.11 and is the only one with a synchronized first gear.
What's the transmission code on the driver's door jamb label?
A: NP435
F: T-18
P: T-19
Also, the NP435 (mine anyway) has the "NP" logo cast near the PTO access plate.
[font color="green"]1995 F-150 Supercab XLT 4x4 302 M5OD 8' bed [/font]31x10.50's
[font color="green"]1986 F-150 4x4 300 I6 NP435 [/font]Warn hubs, DeeZee bed caps, '96 XLT bench seat, new paint job
Old Jul 9, 2002 | 09:26 AM
mchild's Avatar
mchild
What are the other gear ratios in the T-19?
Thanks,
Mark
Old Jul 9, 2002 | 03:45 PM
brown 4x4's Avatar
brown 4x4
1: 5.11
2: 3.03
3: 1.79
4: 1.00
I'm not sure about reverse.
Old Jul 9, 2002 | 07:57 PM
82F100SWB's Avatar
82F100SWB
BigBlue: With the PTO cover on the pass. side, it sounds like a NP 435 to me, easy way to tell, the NP 435 has an aluminum top cover, while everything else is all cast iron.
Evan MacDonald
1982 F100 SWB
300 HD: Cliffy 290H, 9.1:1 compression, forged everything, ARP'd bottom end/Hedman hedder/dual 2½" exhaust
NP 435/2.75 geared 9"
1986 F150 HD, 300 HD/needs a NP 435/4.10 geared 8.8
70,000 miles
1984 F150 XLT Lariat parts donor, 351W/C6/9" LOADED to the hilt, 201,000 miles
1980 F100 Custom, 300/Np 435/2.75, 58,000 miles
Old Jul 11, 2002 | 09:08 AM
bigblue's Avatar
bigblue
Thanks to every one for your help. It is a NP435. I pulled it out of the 86 F150 back in 1988 and installed one with overdrive because I was commuting from Minneapolis to St. Louis. It has been under the work bench for thirteen years. It is now officially for sale, now that I have identified it. Anyone want it? I am in Minneapolis. Thanks
Old Jul 11, 2002 | 09:16 AM
87stxranger's Avatar
87stxranger
artieb
Sep 30, 2015 06:45 PM
Chewy1978
Sep 22, 2015 01:17 PM
redneck_boyd
May 30, 2013 11:08 AM
1981FordF250 Granny
Sep 19, 2009 01:54 PM
Porsche Man
All Things Towing
Dec 21, 2002 12:18 PM
