I broke my DS mirror glass on my 2000 F250 and I was hoping I could get some info on what years (99-07) are interchangeable for the mirror glass/mount only. I had to replace both mirrors 4 years ago after a Bloodmobile sideswiped my truck, I replaced the factory power tow mirrors with a set of factory power mirrors with heat, I think they were from an '01 or '02 model. I really just need the mirror glass and it's plastic mounting pad, the trailer tow mirror assembly doesn't look damaged. I see Dorman has a replacement mirror glass/mount with heat but they are supposed to be for an '05-'07. Please advise if possible, not wanting to purchase a total outside mirror assembly if not needed. Thank you in advance. Todd
I got both of mine (just the glass) replaced by an auto body shop.
Dscabra,
Thank you for the reply, sorry it's a little late been a bit busy and out of town. I was able to do a little research and purchased the Dorman #56311 replacement glass with frame that has heat, put it in just today and works perfect. Thanks again for the reply. Todd
Dscabra,
Glad you found what you needed. My truck got damaged (sand blasted) in a small tornado. I had to have all the glass replaced along with the grille and all the badging/emblems, and the mirror glass. The paint had some signs of pitting, but I opted to pass on the repaint as it would likely not have been as good as the factory paint. Its been three years now and no issues with the mirrors or the paint.
