1978 - 1996 Big Bronco
Front Shocks
Old Nov 17, 2012 | 07:38 PM
dpoc's Avatar
dpoc
Front Shocks
I am working on a 1979 Bronco and trying to replace the front shocks. The one on the driver's side has me a little puzzled. I removed the shock bolt nut and the two bolts that hold on the lower shock bracket. Should have I removed the whole bracket? The shock is located in front of the axle is this correct? There appears to be a busing or a long shoulder on the lower bolt. If it is a bushing how is it removed from the bolt? I got replacement shocks from the local auto parts store and they also had a metal insert inside the rubber bushing that is the same size as the one on the bolt. Is this shock correct? If the shock is incorrect does anyone no where I can get the correct shock from?
Thanks!
Old Nov 17, 2012 | 09:27 PM
CS79bronco's Avatar
CS79bronco
There is a metal sleeve inside the bushing on the bottom end. Your old one is still on the bolt. Try soaking it with PB Blaster or other lube that will penetrate rust. After soaking for a day or two, try to twist the bushing & work it off the bolt. You may have to cut the bushing length-wise & spread it a little to get it off. A Dremel tool with a cutting wheel would probably be easiest. Good luck.
Old Nov 18, 2012 | 02:23 PM
dpoc's Avatar
dpoc
Is the bolt part of the brackets or is that just rust to the bracket as well?
Old Nov 20, 2012 | 07:51 PM
CS79bronco's Avatar
CS79bronco
I think that is rust also. The bolt should come out after you get the sleeve off.
Rocinante
Jul 3, 2014 10:43 AM
dpoc
Nov 18, 2012 06:20 PM
aceltx09
Aug 20, 2010 11:09 PM
streetpreacher
Aerostar
Oct 21, 2004 12:07 PM
tk325
Aerostar
Jul 7, 2004 11:54 PM
