1976 F100 steering problems
Old Nov 21, 2012 | 07:20 AM
breedo99's Avatar
breedo99
Its definately the track bar bracket on the frame. We found it when we moved the steering wheel. Even with a new bushing its walking all over the place in the bracket...
Old Nov 21, 2012 | 02:13 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I meant tractor supply grade washers, not ace hardware stuff. lol
You can probably order a new one from a lift kit supply company, they do sell a trac bar drop bracket when you lift a truck??
Or overlay it with some 3/16ths steel plates on the inner and outer sides.
Old Nov 21, 2012 | 03:00 PM
tbear853's Avatar
tbear853
Originally Posted by breedo99
Is there any other way to fix this without welding washers to the bracket? Or do they make a replacement bracket? Welding washers on seems kinda sketchy...
You mentioned earlier that he put polyurethane bushings in .... mine in my '77 wa a 14 piece kit that included new poly bushings for the track bar and that was 1986, and 26 years later that's still tight.
That bracket is pretty thick. I'ld make sure the frame is not cracked, that the bracket isn't flexing due to cracking either
As to the suggestion of a pair of washers just jack truck up to take weight off, remove bolts holding bracket top frame and track bar bolts. Look close at the bolt and holes, if worn it's a simple fix now. You can alternatively use some steel plate like mentioned above.
You get two heavy gage grade 8 washers same diameter as fit the bolt diameter and then weld to the out side of the bracket on each side establishing new holes. Then you can even build up hole to match washer inside and drill and grind excess. Use a longer Grade 8 or better bolt to attach track bar to bracket. It'll stay until the cows come home!
What wobbles that hole out is loose bolts and/or driving with worn out bushings wich leads to hammering.
rews2
13
May 9, 2014 11:44 AM
MThorns
May 18, 2012 04:06 PM
loyal
May 22, 2009 12:48 AM
73FOMO
Sep 2, 2005 12:23 PM
