can anyone tell me if this is a good balancer to replace the old one i have with. the motor has the stock balancer on it.
1967 352 newly rebuilt with a hotter cam than stock.
I'd check the OD of your's as the you post the link to is 7'5" OD I've seen some guys have trouble and remove or bend the timing pointer to fit over the larger dampers..orich
