Plug problems
Old Nov 13, 2012 | 11:01 PM
crazy96863's Avatar
crazy96863
Plug problems
So here is the issue of the day...
I got these plugs in the freeze plug kit I picked up. The kit provided 4 but I could only locate three on the block... Here is the only one that seemed to go in right (its located on the forward #1 side):
Both of the ones on the #2 side are being a little troublesome, but the biggest issue is the forward plug on the #2 side. The rear plug simply doesnt thread in but a thread or two as indicted in the picture:
The dirty threads are as far as it went in:
The forward plug on the number two side really has me scratching my head as I seem to have drilled it out and tapped threads to the wrong thread count inadvertently; the reason for drilling out is that it had a smaller plug which Didnt come in the kir so I unwittingly assumed drilling and tapping would be a-ok. The threads I cut are 1/2-20. When I compared the plug to the tap, at a glance it looked the same especially when compared to the other tap I had, 1/2-13. At a closer look the plugs seem to be a 1/2-18 thread size which doesnt at all appear to be a standard size; it may be metric but I didnt really look to closely at this possibility as all the other threads on the block are english.
So my question is what is the best approach from here? I was thinking to simply find a short 1/2-20 bolt and thread in as a plug while coating the threads with some sealant. Will this make an effective plug? What grade bolt is best for this... 5, 8, or brass maybe? I dont want to drill this hole any bigger and to change the thread count would essentially require going a size larger. There is only so much meat here and before doing anything else I figured I should come up with a solid plan of action.
Any advice? And what the heck is the purpose of these holes anyway? The freeze plugs obviously pop out when things freeze up so these arent needed for that purpose.
Thanks?
Old Nov 13, 2012 | 11:06 PM
crazy96863's Avatar
crazy96863
This picture illustrates the 'only so much meat' concern I have.
Old Nov 14, 2012 | 01:46 AM
xlt4wd90's Avatar
xlt4wd90
Are you certain you used a pipe tap to cut the threads in the hole? Most pipes use a tapered thread, and requires a tapered tap, not the straight tap for bolts. If you've tapped it with a straight tap, just get a short 1/2-20 bolt (or an oil pan plug), as you said, and use lots of teflon tape around its thread.
Too bad the hole's boss isn't smooth, or you can use the gasket that usually comes with an oil pan plug.
Old Nov 14, 2012 | 11:22 AM
smalltrucker's Avatar
smalltrucker
That should be a pipe tap as said and takes a tapered tap. Equivalent to the 1/2"-20 thd you used would have been a 1/4"-18 NPT. A straight thread is not meant to seal unless it has a '0' ring under a hex hd.
Dave
Old Nov 14, 2012 | 11:25 AM
crazy96863's Avatar
crazy96863
Yeah thats the problem... I used a straight tap. Considering the plug doesnt even come close the threading in, I might still have enough meat to be able to use a pipe tap. Otherwise I could go one size larger.
Old Nov 14, 2012 | 11:26 AM
crazy96863's Avatar
crazy96863
Learning something new everday. To bad its trial by error.
Old Nov 14, 2012 | 11:49 AM
smalltrucker
And the purpose is usually to drill something like cross holes in the oil galleys. A couple are in the back of the block also.
Dave
Old Nov 14, 2012 | 06:01 PM
BlueOvalRage's Avatar
BlueOvalRage
The purpose of those particular holes is to be block coolant drains.
Old Nov 15, 2012 | 07:05 PM
crazy96863's Avatar
crazy96863
I just grabbed the pipe tap... I can tell its the right size but I am confused as to how the size is rationalized. This thing is clearly about 1/2 in size but this and the plugs are considered to have a 1/4-18 NPT. Anyone know the logic behind this?
Old Nov 16, 2012 | 12:43 AM
crazy96863's Avatar
crazy96863
funny how the right tool makes things work so much better.
Old Nov 16, 2012 | 02:48 PM
Beanscoot's Avatar
Beanscoot
Pipe threads are sized by the inside diameter of the pipe back when they were first manufactured. So way back when, a pipe with a quarter inch hole was fairly thick steel or cast iron and ended up with an OD about .54" ins. Then a tapered thread was cut on the ends, and called 1/4 Pipe thread.
As manufacturing improved, thinner walls were used so now a nominal inside diameter is commonly about 3/8".
It's not that strange after all. For instance when we buy a piece of 5/16" fuel hose we are referring to the inside diameter, not its outside diameter.
Old Nov 16, 2012 | 02:52 PM
crazy96863's Avatar
crazy96863
Your right its not strange... I guess knowingtge background better assists in knowing and understanding the sizes.
I had some extra plugs that came with the freeze plug kit so I went all out filling some other holes with them. Figured it was that or tossing them.
Btw... Easy outs make removing the old rusty plugs so much easier.
Old Nov 16, 2012 | 04:57 PM
smalltrucker
Hadn't heard of the history that far back but hard for a lot of people to understand why a 1" pipe is 1.315 OD and a 3" pipe is 3 1/2" od. Same differences across the board with all sizes up to 14". I believe copper tubing is measured two different ways also.
Dave
Old Nov 16, 2012 | 10:03 PM
Beanscoot's Avatar
Beanscoot
Pipe sizing
Dave, you are right that copper tubing is measured two ways. In industry it is measured by OD, but oddly enough house 1/2" copper "pipe" (actually tubing, of course) is 1/2" ID. This terminology is probably a relic of the fact that it replaced 1/2" galvanized (real) pipe.
In industry, this 1/2" copper "pipe" becomes 5/8" copper tube!
And of course there are two different taper pipe thread systems. There is NPT, used in Canada and the US, and possibly Mexico and the rest of the Americas. Then there is British pipe, BSPT, used in most of the rest of the world. It uses different but close thread pitches for most sizes, and the thread profile is 55 degrees instead of 60 for NPT.
This BSPT has been adopted as the ISO metric pipe thread. So there is "Metric" 1/4 pipe thread! I am not sure if US cars use NPT or BSPT/ISO nowadays, although most of the fasteners have been metric for many years now.
The small block V8s happily use good old standard bolts and NPT threads, other than the metric spark plug threads.
dr1
Jul 10, 2014 09:18 AM
crazy96863
13
Nov 11, 2012 10:09 AM
Dodgeyaussie
Jun 19, 2012 07:50 PM
papajoemrt
1997 - 2003 F150
20
Apr 30, 2009 09:47 PM
Cruiseomatic
Dec 22, 2004 08:32 AM
