Plugging the dip stick hole
Old Nov 4, 2012 | 11:47 PM
crazy96863's Avatar
crazy96863
Got a dipstick hole in the block but my application locates it in the oil pan. I am thinking to tap some threads in the hole and plug it with a set screw with RTV on the threads...
Any better ideas?
Old Nov 5, 2012 | 07:03 AM
baddad457's Avatar
baddad457
That's the best way to do it. Or find a cup plug that size and drive it in with sealant
Old Nov 5, 2012 | 08:10 AM
crazy96863's Avatar
crazy96863
I like the cup plug idea... It can be easily be removed if needed. But to find one...
Old Nov 7, 2012 | 06:37 PM
BlueOvalRage's Avatar
BlueOvalRage
I usually tap it for 1/8" pipe thread and use an allen pipe plug.
Old Nov 7, 2012 | 10:06 PM
crazy96863's Avatar
crazy96863
For those who care, here is the end result:
Old Nov 7, 2012 | 10:08 PM
crazy96863's Avatar
crazy96863
Btw... Harbor freight taps suck @ss. Really soft. This one hole rounded it so I bought a made in usa irwin; worked great!
Old Nov 8, 2012 | 01:53 PM
xlt4wd90's Avatar
xlt4wd90
Some things are safe to buy from Harbor Freight, but never buy anything that requires precision, like taps and dies. Not only are they soft, but the threads are "off"; they're not exaclty what the standard sizes should be, so for example, if you tapped a hole for a bolt, the bolt will be loose in there.
Old Nov 8, 2012 | 01:57 PM
crazy96863's Avatar
crazy96863
Yeah it barely cut any threads... The tap basically stripped. It worked for aluminum and for cleaning threads but not for cutting into cast iron.
The irwin tap I used worked perfectly.
Old Nov 8, 2012 | 02:06 PM
crazy96863's Avatar
crazy96863
Old Nov 11, 2012 | 08:45 AM
Sand_Man's Avatar
Sand_Man
I second the fact that some stuff you buy at HF (one of my favorite stores!) is best left there on the shelf. Having said that, one time our company's purchasing agent got a "good deal" on some nuts and bolts (we go through thousands per year) and was going to save the company big money. Instead it actually cost us money because the nuts and bolts usually wouldn't even thread on to each other of the same size and pitch! Also, whenever you are buying taps and dies or even drills, make very, very sure it says HSS on it. That stands for high speed steel and any tap that doesn't have that on there is carbon steel, which is what files are made from. Nearly all the cheap tap sets and drill bits are carbon steel and not even worth the low price they get for them.
Old Nov 11, 2012 | 08:54 AM
crazy96863's Avatar
crazy96863
In a way that store is a perfect example of the Chinese off-loading their garbage on us. I bought the taps cause they were cheap and for a specific which required tapping some holes in cast aluminum; they served their purpose quite well in the respect but failed miserably when I ran it through the cast iron. A self tapping screw would have done better.
I also had a lightly used Craftsman hand grinder burn up on me prematurely and being disgruntled I figured why waste money in it so I went to HF and got another... The fūcker burnt up on me (as in caught on fire) the first time I used it. So yeah I really hesitate to buy anything but consumables and basic hand tools there.
Old Nov 11, 2012 | 09:12 AM
Sand_Man's Avatar
Sand_Man
I actually like the HF place we have locally. The people there are friendly and helpful and as long as you are realistic about what to buy there, I've never been really sorry. I have a sawzall I got for $20 about 8 years ago and it still does fine. Of course, if I used it everyday, I wouldn't have bought it at HF! I also recently bought a borescope there for $70 and I had a 15% off coupon (they hand them out at the door) and I see basically the same thing sold on ebay for $90 plus shipping. I also bought a solar battery charger there a few years back for my toy hauler and when it didn't work, I took it back and got my money back, with no hassles at all. Yes I know what it is and where it comes from, but I need to watch every dollar as do most of us. The way I see it, I'm supporting the local salespeople who seem to be happy to work there, and that's a LOT more than I can say about the guys working the tool department at Sears! You better know exactly what you need there, because you sure won't get any help or advice from them!
Old Nov 11, 2012 | 09:38 AM
baddad457's Avatar
baddad457
Harbor Freight is like any other company now-a-days, quality is a crap shoot, simply going by cost is no longer an indicator of quality. I used to by Sears lawn mowers, but no more. Husqvarna gets my business now. Briggs & Stratton used to be a good name in quality, that went out the door, as did Homelite.
Old Nov 11, 2012 | 10:09 AM
crazy96863's Avatar
crazy96863
I can definitely relate to your comparison of Sears & HF... The contrast of moral amongst the employees is incredible.
Jghake
May 4, 2019 03:14 PM
crazy96863
13
Nov 16, 2012 10:03 PM
boxer.fan
Jul 28, 2010 01:38 PM
mongo75
15
May 28, 2008 06:11 PM
umdstang
Nov 4, 2004 04:34 PM
