missing 360
Old Nov 13, 2012 | 08:56 PM
75fe360hb's Avatar
75fe360hb
missing 360
Hello fellow ford fans. I've browsed the forums and gained valuable info for the last few months, now I finally registered so I can ask some questions and get answers from experienced ford owners.
I have a '75 F250 4X4 highboy with the 360. Took off all the smog, and I put the heads and intake manifold (4 bbl) from my '65 on my highboy. Besides the head and intake swap, I also have an Edelbrock 600 cfm carb. The rest is stock. It was surprising what that little mod did for the power. Getting to my question, when the rpm's get just above 1000, it feels like it is missing. I've changed cap, rotor, plugs, wires. Did compression check and all cylinders are within 10-15 lbs. It runs smooth as silk at idle, but once it gets about 1200 rpm, it feels like a cylinder drops out. Any ideas?
Old Nov 13, 2012 | 09:02 PM
J ballan's Avatar
J ballan
If it was my truck I would check for vacume leaks and make sure the vacume/mechanical advance is working. Good luck.
Old Nov 13, 2012 | 09:08 PM
75fe360hb's Avatar
75fe360hb
There are no vacuum leaks. The timing is dead on, doesn't jump around at all even at higher rpm's.
Old Nov 13, 2012 | 09:16 PM
J ballan's Avatar
J ballan
Did you check your fuel pressure? Maybe the pump is getting weak.
Old Nov 13, 2012 | 09:27 PM
75fe360hb's Avatar
75fe360hb
Replaced the pump a couple years ago. I should probably check the fuel filter again, even though I changed that not to long ago. I bought the truck from a friend a few years ago and it had been sitting on his property for about seven years. There could be some gunk in the tank that is plugging up the filter. I appreciate the feedback.
Old Nov 13, 2012 | 09:29 PM
J ballan's Avatar
J ballan
No problem. Sure sounds like its running out of fuel. These old gas tanks can get pretty nasty.
Old Nov 13, 2012 | 10:00 PM
march's Avatar
march
Have you checked the spark plug wires? I had a problem a couple of years ago. Truck would miss under acceleration/load. Tried all the usual suspects (new fuel pump, etc.). Then one day touched a plug wire and got zapped. Turned out the wire was not seated well on the plug. The weak spark would not fire when the fuel mixture got richer.
Old Nov 13, 2012 | 10:22 PM
75fe360hb's Avatar
75fe360hb
I was wondering about that myself. The plug wires I get now days for these motors never seem to fit quite right. They feel loose on the plug and, at least where I get them from, the boots on the two middle cylinders on each bank interfere with each other. I'm still not sure why it would only miss off idle and not all the time.
Old Nov 13, 2012 | 10:36 PM
75fe360hb's Avatar
75fe360hb
I just thought about this. The Edelbrock carb is supposed to run 6 psi max, does the fuel pump on the ford run a higher psi, and if so, would that cause the problem I'm experiencing?
Old Nov 13, 2012 | 10:59 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Have you tried watching the engine at night or in the dark for spark arcing?
How advance are you running? I wouldn't go more than 12 degrees BTDC on a stock cam, and then set with the vacuum advance disconnected.
Also, you're using ported vacuum for the advance correct?
Josh
Old Nov 13, 2012 | 11:10 PM
75fe360hb's Avatar
75fe360hb
Haven't looked at it in the dark. Good idea. I'm running 10 BTDC on ported vacuum. I've always been a firm believer that it's almost always the simplest solution. I've gone thru the basics, besides the tips you all have given, but I'm starting to think on a more general level. Are there mechanics that could be bad, i.e. lifter, balance etc.?
Old Nov 13, 2012 | 11:27 PM
75fe360hb's Avatar
75fe360hb
Just want to let you guys know, I really appreciate your input. This is a great site and hopefully I can help others out with their questions.
Old Nov 13, 2012 | 11:30 PM
Bullitt390's Avatar
Bullitt390
Just have to throw it out there...
Firing order: 1-5-4-2-6-3-7-8
Normally the rotation starts with #1 terminal about 1 or 2 o'clock and counter clockwise.
Josh
Old Nov 13, 2012 | 11:45 PM
75fe360hb's Avatar
75fe360hb
Yes, I have the firing order correct. I think I need to reiterate that at idle, you can put your coffee on the air cleaner, and there wouldn't be a ripple in your cup. It runs perfectly smooth.
By the way, the three most powerful words, according to my girlfriend, are "three fifty two." The motor that's in my '65. She loves it when I pick her up in that truck. She actually requests to be picked up in the truck. How cool is that.
Old Nov 13, 2012 | 11:55 PM
Bullitt390's Avatar
Bullitt390
As for mechanical:
Did you reinstall the pushrods back to there original positions? For hydraulic lifters there was a standard length depending on year, but post 68 is 9.59" with an over-under available of .060" (There were other over/unders avaible, but somewhat rare to find)
So installing a +60 PR in a lifter that needed a -60 you'll see you are now .120" tight.
Josh
