Hello fellow ford fans. I've browsed the forums and gained valuable info for the last few months, now I finally registered so I can ask some questions and get answers from experienced ford owners.
I have a '75 F250 4X4 highboy with the 360. Took off all the smog, and I put the heads and intake manifold (4 bbl) from my '65 on my highboy. Besides the head and intake swap, I also have an Edelbrock 600 cfm carb. The rest is stock. It was surprising what that little mod did for the power. Getting to my question, when the rpm's get just above 1000, it feels like it is missing. I've changed cap, rotor, plugs, wires. Did compression check and all cylinders are within 10-15 lbs. It runs smooth as silk at idle, but once it gets about 1200 rpm, it feels like a cylinder drops out. Any ideas?
Replaced the pump a couple years ago. I should probably check the fuel filter again, even though I changed that not to long ago. I bought the truck from a friend a few years ago and it had been sitting on his property for about seven years. There could be some gunk in the tank that is plugging up the filter. I appreciate the feedback.
Have you checked the spark plug wires? I had a problem a couple of years ago. Truck would miss under acceleration/load. Tried all the usual suspects (new fuel pump, etc.). Then one day touched a plug wire and got zapped. Turned out the wire was not seated well on the plug. The weak spark would not fire when the fuel mixture got richer.
I was wondering about that myself. The plug wires I get now days for these motors never seem to fit quite right. They feel loose on the plug and, at least where I get them from, the boots on the two middle cylinders on each bank interfere with each other. I'm still not sure why it would only miss off idle and not all the time.
I just thought about this. The Edelbrock carb is supposed to run 6 psi max, does the fuel pump on the ford run a higher psi, and if so, would that cause the problem I'm experiencing?
Haven't looked at it in the dark. Good idea. I'm running 10 BTDC on ported vacuum. I've always been a firm believer that it's almost always the simplest solution. I've gone thru the basics, besides the tips you all have given, but I'm starting to think on a more general level. Are there mechanics that could be bad, i.e. lifter, balance etc.?
Yes, I have the firing order correct. I think I need to reiterate that at idle, you can put your coffee on the air cleaner, and there wouldn't be a ripple in your cup. It runs perfectly smooth.
By the way, the three most powerful words, according to my girlfriend, are "three fifty two." The motor that's in my '65. She loves it when I pick her up in that truck. She actually requests to be picked up in the truck. How cool is that.
Did you reinstall the pushrods back to there original positions? For hydraulic lifters there was a standard length depending on year, but post 68 is 9.59" with an over-under available of .060" (There were other over/unders avaible, but somewhat rare to find)
So installing a +60 PR in a lifter that needed a -60 you'll see you are now .120" tight.
