2011 trans
Old Nov 13, 2012 | 08:37 PM
ken1960's Avatar
ken1960
Question 2011 trans
has anyone had this problem , when i take off in morning truck will change from low to 2nd an hesitate for a second an then go on ok. was sitting at light the other day an went to take off an mashed dn on fuel pedal an it just sit there an then took off, dont no whats going on.:-
Old Nov 13, 2012 | 09:04 PM
BadDogPSD's Avatar
BadDogPSD
It's a common problem for the 2011 & early 2012's. I believe that Ford has issued a TSB for it. Take it to the dealer, it should be covered under warranty.
Old Nov 14, 2012 | 08:08 AM
Rod Bensken's Avatar
Rod Bensken
The just fixed mine. I had the reverse delay and harsh shifting in the first 3 gears.
They replaced a pump inside the tranny, so far all is good. There is a TSB fir this.
Old Nov 14, 2012 | 09:16 PM
ken1960's Avatar
ken1960
2011 trany
what is a tsb fix
Old Nov 14, 2012 | 09:40 PM
Fontana's Avatar
Fontana
I think tsp means technical service board. It's identified trends but not yet worthy of recall.
I may not understand the exact issue here but I can tell you that our trans will run a bit slow until the truck is warmed up. I've only seen this in cold weather. It will shift hard for a mile or so then run fine. If that sounds like your problem I wouldn't be concerned.
Old Nov 15, 2012 | 06:05 AM
Jigger2020's Avatar
Jigger2020
Technical service bulletin, its basically an improvement call........
Old Nov 15, 2012 | 07:02 AM
bridge's Avatar
bridge
Sick 'n Tired
Technical Service Bulletins (TSB) are related to technical issues that need to be fixed. They are usually non-safety related as safety issues usually result in a recall and have oversight by the feds. All manufacturers have a TSB process to communicate known issues and their associated fix. Most first model year vehicles like tge 2011s have numerous TSBs. TSBs are covered under warranty during the factory base warranty period. After that, they are no longer addressed free of charge by the dealer.
Old Nov 15, 2012 | 09:46 AM
my996duc1's Avatar
my996duc1
anyone have a link to the TSB or the TSB number ?
_
Old Nov 15, 2012 | 04:13 PM
I-BEAM's Avatar
I-BEAM
The TSB number for the transmission pump is TSB 12-9-4
Old Nov 15, 2012 | 06:12 PM
_red rocket_'s Avatar
_red rocket_
Regardless of the TSB, don't forget to consider that this is also something inherent to the 6.7L turbo lag. And before anyone comments, I also have/had other turbos, non-truck and quite familiar with turbos and lag. I have had the TSB applied to my 6.7L, the minor lag is still something that you must contend with.
skirk55
May 22, 2008 07:08 AM
countrysF250
Dec 10, 2004 02:42 PM
Hondamototech
Sep 12, 2004 09:06 PM
droFnaF
May 16, 2004 06:14 PM
bobbydrums53
Dec 1, 2003 04:16 PM
