2013 F 150 and weight capacity’s
Old 01-05-2013, 07:34 AM
4570's Avatar
4570
4570 is offline
2013 F 150 and weight capacity’s question...
ecoboost engine, 4x4
compairing the XTR and the FX4 the FX has higher towing and GCWR numbers.
Dealer suggests the brakes, engine and tranny are the same.
So must be suspension.
But what are the differences?
Old 01-05-2013, 07:39 AM
96sherm's Avatar
96sherm
96sherm is offline
If you are comparing the exact same trucks (wheelbase, engine, tow packages, HD/non HD, etc) the specifications should be identical or so close it wouldn't matter in real world driving. I just looked up on the Ford website, and there isn't a difference worth mentioning when it comes to payload or towing. Comparing 2 crew cab 4x4 trucks with the same motor and options (save the interiors or decals on the exterior), the towing capacities are going to be the same and payload may vary by 50-100lbs. Where were you getting your information?
Old 01-05-2013, 11:40 AM
4570's Avatar
4570
4570 is offline
I copied and pasted directly from a ford canada website to excel this info
XTR Package 4X4 6.5'
XTR with XLT Luxury Pkg
FX4 4X4 6.5'
Lariat 4X4 6.5'
Towing capacity
2,767kg (6,100lbs)
2,767kg (6,100lbs)
3,538kg (7,800lbs)
3,538kg (7,800lbs)
GCWR
5,307kg (11,700lbs)
5,307kg (11,700lbs)
6,123kg (13,500lbs)
6,123kg (13,500lbs)
Old 01-05-2013, 11:47 AM
4570's Avatar
4570
4570 is offline
Well the layout did not transfer well.
But it shows the fx4 and lariat with more.
Old 01-05-2013, 03:03 PM
svt2205's Avatar
svt2205
svt2205 is offline
Here's a link to Ford's F150 Towing Guide. In this you wont see much, if anything, about capacities based on models. It's cab/bed configuration, engine and 2 vs 4 wheel drive.
http://www.ford.com/resources/ford/g...rv&tt_f150.pdf
Old 01-05-2013, 07:41 PM
96sherm's Avatar
96sherm
96sherm is offline
The website is hard to read. If you are dealing with the same cab size, bed size, drivetrain, Payload and towing related options, the GCWR/GVWR will only vary by a hundred lbs or so due to interior options.
wildstang
07-28-2011 07:37 PM
Grubbworm
04-21-2011 09:56 PM
Grubbworm
04-21-2011 12:35 PM
flyerdown326
Oil & Lubrication
07-30-2005 06:23 AM
Quick Reply: 2013 F 150 and weight capacity’s
