Water Pump 4
Old Nov 13, 2012 | 06:16 PM
auden's Avatar
auden
Water Pump 4
My 3rd waterpump on my 7.3 is shot.
Original went 115,000 mi. replacement ford pump went 30,000mi. and replacement napa went 45,000 miles. There is no way that these engines should be doing this! Navistar or someone must have upgraded pumps because this is unacceptible. Any suggestions? Thanks
Old Nov 13, 2012 | 06:29 PM
honeydew's Avatar
honeydew
Install a coolant filter with water pump 4
or
install an International water pump with integrated coolant filter: https://www.ford-trucks.com/forums/1...p-install.html
Old Nov 13, 2012 | 06:49 PM
Firefighter 1406's Avatar
Firefighter 1406
I went with the filter system from dieselsite.com, nice system and easy install.
Old Nov 14, 2012 | 12:47 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Are you maintaining your coolant? How about using ELC? Neglecting those will cause you to go through pumps. I also second the coolant filter.
Old Nov 14, 2012 | 01:45 AM
SpringerPop's Avatar
SpringerPop
I believe I would seriously consider checking the balance/runout of the fan/clutch/pulley assembly.
You may have bent or damaged something during the first (somewhat normal mileage) replacement that is now continuing to eat pump bearings.
Check the pressure at which your "radiator" cap actually relieves. Higher coolant pressures may cause coolant to seep past the seal and "wash out" the bearing lubricant.
Pop
Old Nov 14, 2012 | 03:04 AM
Stewart_H's Avatar
Stewart_H
Hmmmmmm.......
For auden and Trey, how are you guys removing the fan clutch nut? With the proper tool or with an air chisel like some guys have done?
Stewart
Old Nov 14, 2012 | 03:49 AM
Pitcrw6's Avatar
Pitcrw6
X2 on what Pop said.
Old Nov 14, 2012 | 07:04 AM
Firefighter 1406
I always rent the tool myself.
Old Nov 14, 2012 | 11:04 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Never used the air chisel. I always used the rent-a-tool or monkey wrench.
Old Nov 14, 2012 | 12:26 PM
clem1226's Avatar
clem1226
failed fan clutch maybe?....possibility that the fan clutch is running 20 or 30%+ engaged (not enough to roar but enough to be heard if listening for it) all time adding additional steass to the pump bearing?
Old Nov 14, 2012 | 02:14 PM
SpringerPop
Why do you feel that additional stress would be placed on the bearing?
Pop
Old Nov 14, 2012 | 02:36 PM
clem1226's Avatar
clem1226
Pop
I ponder that our fans are not precisely balanced....if they are locked a large amount of the time that imbalance may translate to osculating loads being placed on the water pump impeller shaft. ?
Old Mar 16, 2014 | 01:32 AM
Dually4by's Avatar
Dually4by
I know this is an old thread but I'm having the same issue. I am on my third water pump and on my drive home from work, I can hear squeaking from under the hood. As I suspected, the shaft on my water pump was shaking just like the second water pump I had. I can see that the fan clutch needing replacement also to be the logical reason I am replacing so many water pumps. My 7.3 has only 202k miles on it and it runs great.
Old Mar 16, 2014 | 06:14 AM
Supercab's Avatar
Supercab
Wink
+2 Excellent filter setup!
Old Mar 16, 2014 | 10:13 AM
mueckster's Avatar
mueckster
I was in the same boat as you. I am on my 4th water pump replacement. Each time they were replaced I had some weepage from the seal and/or small drip when cold weather set in. The last one was an actual bearing failure, but not catastrophic. Thank goodness. I am running ELC, coolant filter, and have already replaced the cap, radiator (cracked neck) and degas bottle (crack). I decided to replace the fan clutch with the last water pump and have no signs of leaks for almost a year. I do feel the fan clutch may had been a big part of my earlier failures. So far, so good. Keeping my fingers crossed.
Bluediesel250
Jul 27, 2017 01:11 AM
RedDevil460
18
Feb 20, 2016 08:49 PM
Jointasset
Jan 23, 2016 05:40 PM
RRranch
Aug 9, 2010 09:46 PM
GoCamping
Feb 3, 2007 09:57 PM
