$75 Tranny Cooler
Old Mar 15, 2014 | 06:13 PM
vtown00's Avatar
vtown00
$75 Tranny Cooler
If anybody wanted to know what one from a salvage yard looks like here it is from a 2005 F350 6.0....
https://www.flickr.com/photos/708643...7642405661224/
Just a couple questions I thought it was a 31 row, this seems to be 32? Also any idea how much more coolant you use with one of these?
Old Mar 15, 2014 | 08:15 PM
Scerb's Avatar
Scerb
I would be cautious using one with an unknown history. Would suck to pump a bunch of clutch debris into your trans....
It won't take much extra fluid at all, assuming you don't spill much during the swap. Less than a quart most likely.
Old Mar 15, 2014 | 08:29 PM
vtown00's Avatar
vtown00
Yea I'm going to run the air nozzle all over it, and it came with the good ol 60 day guarantee.
Old Mar 15, 2014 | 08:39 PM
snakedoc's Avatar
snakedoc
when i put on a trans cooler i use the old fluid to wash out the cooler, i hope 18qt would take out any junk that might be in there.
Old Mar 15, 2014 | 08:47 PM
SpringerPop's Avatar
SpringerPop
If I were to ever get a used one for my truck, I would first make sure the inside was spotless, then lastly rinse it with the solvent the refrigeration guys use. If there were any hint of anything that came out (through filter paper for disclosure's sake), the unit wouldn't get used at all.
I count 31 rows.
Pop
Old Mar 15, 2014 | 08:54 PM
vtown00's Avatar
vtown00
I was wondering about what kind of degreaser to use, but the refrigeration cleaner is a great idea, thanks.
Old Mar 15, 2014 | 08:58 PM
Crewcab Turbo's Avatar
Crewcab Turbo
Napa sells transmission line and cooler flush in an aerosol can.
Old Mar 15, 2014 | 09:13 PM
Scerb's Avatar
Scerb
I used this stuff to clean out OTW radiator line. I still dont recommend using a used trans cooler with unknown history... they are very hard to clean out once contaminated.
Amazon.com: Dr. Tranny 19001 Kooler Kleen Flush Cleaner with Universal Tip: Automotive Amazon.com: Dr. Tranny 19001 Kooler Kleen Flush Cleaner with Universal Tip: Automotive
Old Mar 15, 2014 | 09:15 PM
Crewcab Turbo
That's the same brand that Napa sells.
Old Mar 16, 2014 | 11:41 AM
timmyboy76's Avatar
timmyboy76
31 rows here, too. Could you not take it to a radiator shop and have them clean/flush ur out?
cutlass
Feb 10, 2012 12:44 PM
lucaslaw
Apr 18, 2011 08:57 PM
pastormiketkd
Oct 17, 2008 08:17 PM
MikeSDK
32
Jun 11, 2007 10:31 PM
bdrummonds
31
Apr 13, 2007 10:31 PM
