4WD VS 2WD TECHNICALS
Old Nov 13, 2012 | 11:43 AM
ArtsBest's Avatar
ArtsBest
The 4WD option (vs 2WD) in most vehicles across the board is another $3K or so. Are there that many add-ons and additions besides the obvious front wheel systems that are the reasons for this dollar amount?
Are the shocks, springs and frame a "heavier" quality of materials too or are the costs mostly attributed to the front wheel drive mechanism?
Old Nov 13, 2012 | 12:28 PM
Christin's Avatar
Christin
Transfer case is big bucks and axles are expensive, price them out you will see
Old Nov 13, 2012 | 12:35 PM
YoGeorge's Avatar
YoGeorge
The cost is far less than a conversion would cost, but option and trim level costs have always been a way for manufacturers to add more profit to a vehicle. Are rubber floor mats worth the $95 option cost, for instance? I'm guessing that they cost $10 or $20 to make...
You could always analyze the cost of a meal in a restaurant, or the price of beer in a bar, too... Ford and other companies are in the biz to make money.
If you need 4WD, there is no question that it is worth the price. If you don't need it, you have to consider if it is worth $3k to "wear" a 4WD truck--and add the extra fuel costs, etc, to the equation as well. 2WD with a limited slip rear axle and a good driver can do a lot in normal road situations, but if you are going to go off road, spend the money.
George
Old Nov 13, 2012 | 12:39 PM
khadma's Avatar
khadma
Carpenter Local 745
Also factor in the "coolness" of a 4x4 and the demand.
Ford does know that people will by a 4x4 even at the higher price tag.
The additional front drive parts (or rear on modern SUVs) does add
quite a bit of cost to the truck.
I an not sure that the frames between 2wd and 4wd are that different
(someone may have more information on this).
Some 4x4s will have tow hooks, skid plates and better shocks.
I like having the 4x option on my trucks, just in case.
Old Nov 13, 2012 | 01:18 PM
awq134's Avatar
awq134
as previously stated, axles and transfer cases do cost quite a bit. You also have to consider the added hubs for the front wheels as well as the plumbing for the vacuum lines. Also, the 4x4 sits about 1 1/2" to 2" higher. the rear end has a 1 1/2" block between the axle and the leaf springs. Not sure what they do to lift the front end though.
walbert52
Jan 8, 2011 11:19 AM
chris5301
1997 - 2003 F150
Dec 29, 2009 04:25 PM
hutch75
Nov 16, 2007 08:33 PM
BookBoy
Nov 8, 2005 06:09 AM
fordboyfreak
Mar 3, 2004 10:02 PM
