Block Heater ?
Old Nov 16, 2012 | 10:59 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
I did a little video of my temps and volts to show how long the glow plugs stay on.
This was a 9 hour over night plug in. Over night ambient was mid to high 30's. You can watch the volt readings to see when the glow plugs turn off. (watch the time on the video) Wait to start light went off immediately. Also, you can see the drop in temps as the fluids mixed.
ECT=125* (F)
EOT=108* (F)
Old Nov 16, 2012 | 11:41 AM
kidoo's Avatar
kidoo
I would say if you plug it, it is easier on the components and on the injectors, oil is more fluid. For what it cost, I just plug it in.
Old Nov 16, 2012 | 06:54 PM
04badford's Avatar
04badford
WOW the temps took no time to heat up , by the way amdriventolive I do have a plug had to hunt not much room do you cut the zip tie and feed thru or add a pig tail also mine has a 110 cap over the plug behind fog lamp right ? Havent had time to follow the other wire it looks pinched wheel mud gaurd and frame drivers side does any body have this ,Sorry didnt mean to Hi jack
Old Nov 16, 2012 | 07:05 PM
amdriven2liv
Cut the zip tie.
mblayton
Ford Truck Parts for Sale
Jan 9, 2017 05:53 PM
smithrock
Dec 9, 2011 03:37 PM
JonArmy
Nov 19, 2011 06:16 PM
'06 Dually Boy
Mar 1, 2006 01:00 PM
94 1/2 stroker
Jan 2, 2006 11:14 PM
