Block heater current draw
Old Feb 27, 2006 | 06:41 PM
'06 Dually Boy's Avatar
'06 Dually Boy
Can you guys tell me how much current the block heater draws? I'm curious if my timer is up for the task. Thanks in advance.
Old Feb 27, 2006 | 08:31 PM
LVEILLON's Avatar
LVEILLON
I think I saw someone posted that it's around 600watts...? That's a good bit of draw.
Old Feb 27, 2006 | 11:25 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Draw is between 1,200 - 1500 watts.
Its a lot so use a heavy-duty extension cord and timer... cheap ones will melt or get very warm.
Good luck and please advise what kind or brand of timer you chose... I want to get one to... however, the weather in KC went from 7 degrees last weekend to the 60's today and 80's by Thursday here in Kansas City!!!!!
Old Feb 28, 2006 | 12:40 AM
LVEILLON's Avatar
LVEILLON
WOW...I didn't know it pulled that much!
Old Feb 28, 2006 | 12:42 AM
'06 Dually Boy
I knew it was quite a bit. Someone calculated that it would cost like $50 a month to run it all the time.
Old Feb 28, 2006 | 12:44 AM
Beachbumcook
Got Diesel?
I used a 14 guage extension cord (25') and the wire and plug was warm (not hot). I upgraded to a 12 guage 25' cord from Home Depot and all is well.
If you plug in for 4 hours or more, you will feel the upper radiator hose as being warm... so yu know its working. It is heating up a lot of coolant and the block (where the coolant is touching)... so it takes some wattage to do so. This is serious truck stuff here.... no wimpy heating element for the PowerStroke Diesel!!!
Old Feb 28, 2006 | 01:03 AM
Cowboy Brett's Avatar
Cowboy Brett
Yeah, be sure to use a good, heavy gauge cord. We're talking 10-12 amps worth of draw here. It does do a pretty good job of keeping it warm, though...
Another word of warning should go out to those of you with those newer style GFCI outlets...if you have a plug on your cord that it corroded up, you might go out the next morning and find yourself with a popped GFCI and a cold truck. That has come up on here before.
Old Feb 28, 2006 | 01:21 AM
ford390gashog's Avatar
ford390gashog
the heater draws 11 amps @ 120 volts.
Old Feb 28, 2006 | 07:49 AM
Bosko's Avatar
Bosko
Intermatic HB31R
I am using a heavy duty extension cord attached to the Intermatic HB31R, an heavy duty outdoor timer sold for $19.99 at Home Deport. A Google search reveals it being sold for less if you care to pay for shipping, etc. If the temperature is forecast to drop below 30 degrees, I connect it to the truck. I program the timer to deliver current 3 hours before departure. It works.
Old Feb 28, 2006 | 02:12 PM
2002X's Avatar
2002X
I ditto Bosko. I have the exact set up and do the 3 hour time. I use the cord that goes to the electric start on my snow blower. Heavy duty and only 6 feet long. Perfect for me as I had the builder of my home put a outlet right where i knew I would need one for my truck.
Old Mar 1, 2006 | 12:57 PM
LA2005F250's Avatar
LA2005F250
Wink
I do the timer thing also. I have a timer that I got from Harbor Freight and I can select up to a 15 minute interval. I have my timer come on for 1 hour then off for an hour....running a total of 12 hours a day. Here in the Cincinnati climate area it works out perfect. The truck is warm enough to keep the white smoke down and the sounds much quieter when the truck is put into gear under load. My truck used to be SO LOUD before it warmed up, but not anymore.
The timer is only $ 5.99 and you can order online. My timer is for 115 volts and I believe that it is rated for 15 amps according to the label on the back of the unit. It does not say the amperage rating on the web site, but to verify you could call the store and ask. The link is below.....
http://www.harborfreight.com/cpi/cta...emnumber=40148
Old Mar 1, 2006 | 01:00 PM
LA2005F250's Avatar
LA2005F250
Wink
Just found the online manual for this timer. It is rated for 2000 WATTS. So, your good to go if you want one of these.
Pitweiller13
152
Jan 15, 2016 01:44 PM
bobcf
Jan 15, 2015 06:40 PM
Trucker51
Jan 22, 2009 08:33 AM
QUINCE
Nov 6, 2008 10:40 AM
kooper909
Jul 9, 2006 09:51 AM
