Question about 2003 F150 w/4.6 Need to find out if programming is possible to start truck using the panic button on the keyless entry remote? Would like to be able to do this w/programmer that I purchase. Will consider taking it to dealer but not crazy about it.
I'm not quite sure if I understand your question correctly... are you trying to reprogram the truck's receiver to start the truck instead of setting off the horn? What type of programmer did you purchase and what is it normall used used for?
