Hey guys project is an 02 with newer rebuilt engine turbo failed puked its guts completeley! Dumping massive amounts of oil in the exhaust I believe that the engine is ok. Truck is bone stock save for a muffler delete.
What is a good replacement turbo truck will most likely recieve a chip in the future allong with exhaust.
I fiqure there has to be a few options out there just looking for some advice!!
The big thing here for a while was the 38r, but there are so many different options, I sent you to this site because of price, and customer service. For more info, check signatures, PM, and ask questions.
If thats all your going to be doing to the truck a stock turbo, van turbo or the 38R is what I personally would narrow it down to. If your on a budgetyou can always look on CL or Ebay just be weary if the deal sounds too good to be true it might just be.
Depending on how bad yours is you could just rebuild it if thats an option
The reason the 38R was and is a good option for what you are planning is because it is a drop-in replacement performance turbo. You can probably find a cheap stocker and re-build it for piece of mind for 100 dollars and add a wicked wheel or ported shroud.
