diff and transfercase iden.
Old Oct 23, 2009 | 12:00 AM
bigb9582's Avatar
bigb9582
tring to figure out what front diff. and transfercase is in my 86 f250 6.9 diesel.
these is what the tags say. for what i can make out of what they say.
tranferscase
D296 31345 21
252390 E3TA GB
front diff
3.54 E6TA - JC
610264 - 2
i know the real is a 10.25 full floter with 3.55 gears and i have a c6 tranny.
btw i know the transfer case calls for mercon fluid but all i can find is the dexIII/mercon fluid. will that be safe to use??
Old Oct 23, 2009 | 12:12 AM
bghnkinf250's Avatar
bghnkinf250
The transfer case should be an NP208 if it is stock. The front axle could either be a Dana 44 (likely) or a Dana 50. An easy way to tell is if the hubs taper down (Dana 44), or it they say relaitvely the same diameter.
Old Oct 23, 2009 | 02:07 AM
82F100SWB's Avatar
82F100SWB
Your front end is a 44HD by the Dana BOM, 3.54 gears, open differential.
The transfer case should be a BW 1345 in that truck, not the 208, but a 208 is entirely possible as it is a direct swap though.
If it's a 1345 it will look like so:
Old Oct 23, 2009 | 02:48 AM
bigb9582's Avatar
bigb9582
yep thats what my tranferscase looks like.
i believe the front hubs look all the same diameter the hole way down, i ll have to check. idk come to think of it they might have a slight cone shape, i cant remember off hand.
Old Oct 23, 2009 | 03:16 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by bigb9582
tring to figure out what front diff. and transfercase is in my 86 f250 6.9 diesel. these is what the tags say. for what i can make out of what they say.
tranfer case
D296 31345 21
252390 E3TA GB
front diff
3.54 E6TA-JC
610264-2
Transfer Case
E3TA-GB or E3TA-7A195-GB = Warner Model 1345.
Front Driving Axle
Ford ID numbers: E6TA-JB or -JC // Dana ID number: 610264-2 = Dana 44 / 3.54-1 / No Free Running Hubs / No Limited Slip.
Info source: 1980/89 Ford Light Truck Parts Catalog.
Old Oct 23, 2009 | 03:58 AM
bigb9582's Avatar
bigb9582
cool thanx!!!!
now is dex3/mercon tranny fluid safe to use in the tranfure case?? or just strait mercon
Old Oct 23, 2009 | 10:06 AM
bghnkinf250
A little off subject, when did Ford start to use the 1345? Mine has a 208 and is a 1986 - just wondering.
Old Oct 23, 2009 | 11:20 AM
82F100SWB's Avatar
82F100SWB
ATF is the called for lube for all post 80 transfer cases, they're really not too particular about which spec it is though.
As for the 1345, Ford started using it in '80, it's most prevelant in Broncos and high GVWR F250's/F350's though. A 6.9 or 460 is a pretty good indicator of the presence of a 1345. But, like I said, a fixed rear output 208 is a direct bolt in swap.
Old Oct 23, 2009 | 04:31 PM
bashby's Avatar
bashby
Dextron3/mercon is the proper fluid
Mark_in_co
Mar 9, 2017 01:52 AM
Firefighter 1406
Oct 20, 2016 02:50 PM
AmmoDawg
Jan 8, 2013 09:26 AM
Urban_Prisoner
Jan 17, 2011 08:56 PM
UaVaj
Jan 9, 2011 06:04 PM
