changing differential fluid
Old Jan 29, 2012 | 10:51 AM
countryshiz87's Avatar
countryshiz87
how should i go about changing the diff fluid in my 1990 f250 4x4. the rear diff seems easy enough to pull off the plate and let it drain. but the front with the i beam setup seems like a pain in the ***. my auto tech teacher told me just to suck it out with a turkey baster or something. any recomendations?
Old Jan 29, 2012 | 11:57 AM
Edgethis's Avatar
Edgethis
Sucking it out of the diff is the easiest way.
Old Jan 29, 2012 | 08:40 PM
juni88126's Avatar
juni88126
Is the diff a dana 44 or a dana 50. My 91 axle is a dana 50 and it has a square plug on the center section itself.
Old Jan 30, 2012 | 11:58 AM
countryshiz87
not sure its a 410 tho and it has the square plug but its for filling i thought
Old Jan 30, 2012 | 12:11 PM
kd0axs's Avatar
kd0axs
You can suck it out, but a turkey baster won't work. You need something with a hose that will reach all the way to the bottom of the diff. I used to use a suction gun when I had TTB trucks. Looks like a grease gun but it's more like a huge syringe. Just pull back the plunger to suck the oil out.
Old Jan 30, 2012 | 12:17 PM
TheWhiteBeast's Avatar
TheWhiteBeast
That's what I did. I was dumbfounded when I pulled the fill plug and oil started coming out, but when I started sucking out the fluid I found that it was full of water.
Old Jan 30, 2012 | 08:34 PM
countryshiz87
ok thanks for the advice im sure i can rig something up. and yea i bet theres water in mine considering ive driven through lots of puddles and creeks without changing it
Old Jan 31, 2012 | 11:37 PM
xxshine's Avatar
xxshine
Consider installing a plug at the bottom. It's not that difficult.
Old Jan 31, 2012 | 11:41 PM
ChristopherN's Avatar
ChristopherN
If you're talented in the word of drilling and tapping your own holes.
Old Jan 31, 2012 | 11:57 PM
xxshine's Avatar
xxshine
Just don't drill the hole O.D. to close to the tap size O.D. Plug will strip out easier.
TC-Countryboy
Mar 3, 2026 07:40 AM
kilich
Apr 1, 2011 08:11 PM
cjcocn
Apr 4, 2009 05:52 PM
knapikmichael
Jan 15, 2007 10:25 PM
