2001 f 250 4x4 front hub
2001 f 250 crew cab, lariat, 4 wheel drive, took truck to alignment shop for front end check and when they removed right front hub they found that the large spring in the hub was broken. Have not had any luck in finding a replacement spring. Every one wants to sell the entire hub assembly which does not seem reasonable to replace the unit to acquire the needed part.Does any one have any suggestions/advice? If i have to replace the assembly what do i need to look for, such as electronic/manual units,specs. etc. Any help would be greatly appreciated. Thank You
C.D. Zook
C.D. Zook
Hub
What large spring do they mean? I have had my hubs off and the only spring I remember is the one for the four wheel drive.
Do you mean the the locking four wheel drive hubs?
I replaced my old ones with the new Warn units from RifRaff.
I still have the old ones and they work ok, just ugly. I plan to put them on EBay soon.
Hope you get your problems fixed.
I have a pair of auto lock ESOF 4x4 hubs from a 2003 Excursion. Nice shape, complete, worked fine, but replaced them yesterday with Warn hubs.
$100 for the pair.
Scott
sd_walters@hotmail.com
$100 for the pair.
Scott
johnarahill
12-10-2003 08:17 AM
