1996, F150 Down Shift Problems
Old Nov 8, 2012 | 01:24 PM
ssn647's Avatar
ssn647
Wondering if someone can shed some light on my issue / issues I'm having with my 1996 F150, 5.8, E4OD, w130,000 Miles, 2" Suspension Lift with 33"
Yesterday when driving home my truck did not want to shift down when I steeped on the accelerator (passing gear) I tried multiple times but it just stayed in the higher gear. The speedometer seems to waiver and does not appear the be accurate. It also seems to shift rough sometimes between gears most noticeably when decelerating. From what I have read the VSS might not be functioning properly. Could this cause the rough shifting as well. I have not taken it to have the codes read yet. It seems to be going thru a lot of fuel as well, but she has never been a gas sipper.
I have also been noticing a lack of power, (this might just be me being over sensitive) but for a 5.8 liter V8 it just doesn't have the kick I would expect.
Old Nov 9, 2012 | 04:10 PM
Justis01's Avatar
Justis01
Pull the codes, betcha it's a bad TPS sensor.
Old Nov 9, 2012 | 04:29 PM
ssn647's Avatar
ssn647
I checked last night no codes came up. From what I have been reading it could be the VSS or the TPS.
Old Nov 9, 2012 | 05:16 PM
White 97 xlt's Avatar
White 97 xlt
No codes at all???? You should have gotten a 111, or 11 depending on the year....
If you got no codes at all your reader is NOT communicating with the truck....
Old Nov 9, 2012 | 05:30 PM
ssn647's Avatar
ssn647
I borrowed a code reader from a friend. I might not have used it correctly. I'll go to a parts store and see if they will read it with their machine for free. I can also see how much a VSS or TPS will cost me. While im at it I think I will try and replace the O2 sensors since I have never done that. Im hoping its an easy fix, trying to get this resolved this weekend.
Old Dec 29, 2012 | 12:39 PM
ssn647's Avatar
ssn647
Update. Took the truck to a shop. They pulled bad tps codes and misfire codes. Replaced the TPS, New Plugs, Cap, Rotor, Wires. The mechanic said it corrected some of the shifing issues but now the MAF sensor is bad. He said the MAF could be part of the problem. I was wondering if this is correct or if I am getting the run around. The TPS and the MAF talk to the PCM which tells the tranny when to shift? Any comments? Advise?
Is there anything that coluld be the problem before the MAF?
This is my first time to this shop, they seem pretty well respected around here.
Old Dec 29, 2012 | 12:50 PM
DRRXR's Avatar
DRRXR
Any work or checking done on the VSS?
Old Dec 29, 2012 | 03:06 PM
ssn647's Avatar
ssn647
No VSS codes. I tried replacing the VSS a few weeks ago. The new one worked worse than the old one. Which would back up the other posts that I have seen saying the aftermarket sensors are crap (aside from Mortorcraft). I did post that the spedo was wavering but after reading other posts and seeing some examples of waivering spedos, mine was not that waivering that bad at all.
Long story short, no VSS codes but it is something I will bring up again with the shop. Thanks.
Any other ideas?
Old Dec 29, 2012 | 03:11 PM
pfogle's Avatar
pfogle
The MAF can cause all sorts of issues. It's what tells the computer how much air is coming into the engine. If it's not reading properly then the engine won't get enough fuel or will get too much. The transmission shifting could very well be a pressure problem caused by the bad MAF being a choke point and the engine not responding correctly to throttle input.
Old Dec 29, 2012 | 03:30 PM
ssn647's Avatar
ssn647
Thanks for the reply. Hope this takes care of the problem. I like the truck.
Are there any shift sensors in the tranny that could be doing this?
shawbran
Nov 13, 2024 12:53 PM
kameronth
May 27, 2014 09:51 AM
ssn647
Nov 8, 2012 09:00 PM
IJRoorda
17
May 9, 2012 08:42 AM
Jesse1989
1978 - 1996 Big Bronco
May 4, 2011 06:13 AM
