460 to 6.9
Old Nov 6, 2012 | 10:05 PM
1989_f250's Avatar
1989_f250
460 to 6.9
i have a 89 f250 with a 460 and plan on swapping out with a 6.9 and 4speed, the question i have is will it bolt right up in the 460 mount location or will i have to move the crossmember, any info would be great
Old Nov 6, 2012 | 11:09 PM
typefour's Avatar
typefour
You will need diesel frame and engine mounts, otherwise it fits right in.
Old Nov 7, 2012 | 03:00 AM
BikeMaker's Avatar
BikeMaker
On mine, the 460 frame mounts were riveted on. Cut them off with a torch, and bolted up the diesel frame mounts off of the donor truck.
And the frame mounts that I am referring to are what go between the engine cross member and the rubber isolated motor mounts. Crossmembers are all in the same location, regardless of engine.
Old Nov 7, 2012 | 01:39 PM
1989_f250's Avatar
1989_f250
i dont have a donor truck just the engine and tranny, what are the differences between the frame mounts?
Old Nov 12, 2012 | 07:51 AM
ke5adb's Avatar
ke5adb
If it was me, I'd keep the 460. Properly tuned, I've gotten 12-13mpg out of one in a '86 crewcab with 4-speed and 4.11 rear. The 6.9 isn't worth swapping IMHO.
Old Nov 12, 2012 | 04:58 PM
1989_f250's Avatar
1989_f250
the 460 is no longer efi and built to pull in a street class have no more time to pull it so swapping it out with something that doesnt get 6 mpg
Old Nov 12, 2012 | 06:12 PM
whalebus2112's Avatar
whalebus2112
Yea maybe if your empty and never go over 45 mph down a hill. I have owned several 460s and they all get single digits unless youy are parked.
I am going to go this route also. I have a strong low milage 6.9 in my extra cab but I want a CCab so I plan on finding a nice gas cc because poeple are giving these gas pigs away now.
Old Nov 12, 2012 | 07:08 PM
ke5adb's Avatar
ke5adb
The 460 crewcab stayed hooked to a 24' gooseneck horse trailer with living quarters. That's running 55-60 mph. The older lady that is driving it now still gets 13mpg with the trailer.
Old Nov 12, 2012 | 07:10 PM
ke5adb's Avatar
ke5adb
BTW from Stillwater, Ok to Sallisaw, Ok with 3 horses, we've recorded 15.3 mpg once with it. A little over 1/2 tank used in 167 miles.
Old Nov 12, 2012 | 08:35 PM
1989_f250's Avatar
1989_f250
ya 15.3 with a stock engine, its a little different when the intake, heads and exhaust are opened up and a bigger carb dumping fuel in
Old Nov 13, 2012 | 04:39 AM
ke5adb's Avatar
ke5adb
I was just making a point that you can get get decent mileage with a carbed big block.
Chris Guthro
WTB - Parts & other
Apr 12, 2013 07:30 PM
Chris Guthro
Jan 25, 2013 07:12 PM
oldmansimek
Dec 25, 2006 11:50 AM
BigBlockFord3
17
Nov 9, 2004 10:22 PM
timbawolf2
Nov 4, 2002 12:57 PM
