460 frame mounts
Old Jun 30, 2002 | 07:27 PM
timbawolf2's Avatar
timbawolf2
460 frame mounts
need too know what frame mounts will work on my 78 ford,trying to swap from a 351m-to 460 and the frame mounts are almost impossiable to get,the motor mounts are no problem but the frame mounts are,i've found alot of the early f100 had different frame mounts,but the 77-79 had something else,is there another mount or can someone let me know where i can get them for a small price i've found what i think are them but they want $300.00 for them,help.
Old Jun 30, 2002 | 11:17 PM
gray79f250's Avatar
gray79f250
460 frame mounts
keep the c351m frame perches and use advanced adaptors mounts [my choice ] or the expensive l&lmouts no need to change whats already on your frame
Old Oct 2, 2002 | 11:06 PM
phantom429's Avatar
phantom429
460 frame mounts
Old Oct 13, 2002 | 05:43 PM
331250165r's Avatar
331250165r
460 frame mounts
try a set of 1965 352 mounts for a 2wd truck they only have 2 holes to bolt to the block. you will need to enlongate them slightly and install them on the 460 block at an angle using 2 of the 3 bosses on the block. this mount has stock style stud that extends through the frame horns, worked great on my 81 2wd f100. cheap too.
Old Oct 13, 2002 | 09:31 PM
Ford79's Avatar
Ford79
460 frame mounts
Are you putting the 460 in a 2wd or a 4x4?
Old Oct 16, 2002 | 11:01 AM
laptopgeek's Avatar
laptopgeek
460 frame mounts
Timbawolf ---
Would the pix at *http://www.beedzncomputers.com/truck/engine/mounts/mounts.html* be of any help to you?....
Regards,
Old Oct 31, 2002 | 07:39 PM
fordlowboy's Avatar
fordlowboy
460 frame mounts
[updated:LAST EDITED ON 31-Oct-02 AT 08:41 PM (EST)]hi
i did this conversion and i used Hooker frame mounts, got'em from SummitRacing.com ($126.00) need the Ford motor mounts and shells. and this way you can add headers with out looking ugly! i bought hooker headers too.
http://store.summitracing.com/default.asp?target=%2Fsection%2Easp%3Fd%3D4%26s%3D 164
Old Nov 2, 2002 | 09:21 PM
qtrmiler's Avatar
qtrmiler
460 frame mounts
I can get a complete set-up for around $100... bolt in.
Old Nov 4, 2002 | 12:57 PM
glenb's Avatar
glenb
460 frame mounts
fordlowboy is right, i used the hooker motor mount perches,
they bolt rightup and use all the original motor mounts,
and give you alot more room than those expensive l&l stuff.
good luck glenb
1977 f250 4x4 460
glenb@ev1.net
trick26
Dec 23, 2013 09:14 PM
gomer450
Dec 3, 2013 03:06 PM
hasteranger
24
Apr 5, 2011 01:09 PM
montymbad
Engine Swaps
Aug 27, 2008 02:37 AM
oldmansimek
Dec 25, 2006 11:50 AM
