Aih plug
Old Nov 6, 2012 | 07:24 PM
yfz 450's Avatar
yfz 450
Aih plug
i was starting to install my gauges today, I ordered the 3 gauge pack from riffraff. When I remove the aih to install the boost sender what do I do with the wires and relay? Do I just take it all off?
Old Nov 6, 2012 | 07:47 PM
binuya's Avatar
binuya
I just disconnected and removed the uneeded wiring. I did leave the relay in there as a back up just in case the GPR goes out.
Old Nov 6, 2012 | 07:52 PM
yfz 450's Avatar
yfz 450
Ok sounds good. Next thing is when I run the power and ground wires for the 3 separate gauges I can just tie the 3 gauges together and run 1 wire to a power source and 1 to the ground rather than all 3
Old Nov 6, 2012 | 07:55 PM
honeydew's Avatar
honeydew
The dfuser instructions contain somewhat helpful pics:
http://www.dfuser.com/Install%20Guid...2004-05-02.pdf
Old Nov 6, 2012 | 09:16 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Here you go
http://www.riffraffdiesel.com/mm5/RE...s_AIH_PLUG.pdf
Old Nov 7, 2012 | 03:46 AM
Tugly's Avatar
Tugly
This might help:
Old Nov 7, 2012 | 06:55 AM
yfz 450's Avatar
yfz 450
tugly what are those connectors called i have never seen them. i am not to savy with electric. do you have the dimmer hooked up too? i dont mean to be a pain but can you kind of explain to me waht you did. i can see it but it is hard to tell exactly waht is going on in there.
TennesseeMustangPerf
Mar 21, 2010 09:10 PM
Blankie
Feb 14, 2009 09:52 PM
foxracer800
Feb 9, 2006 02:30 PM
carwash
Oct 14, 2005 02:50 PM
jamesj
Apr 28, 2004 01:29 PM
