I GOT IT I GOT IT
Old Nov 6, 2012 | 06:12 PM
Canadianpowerstroke's Avatar
Canadianpowerstroke
I GOT IT I GOT IT
yaaaaaaaaaaaaaaaaaaaaaa
what a awesome pice of kit this is. SO many gauges i'm like a kid in a candy store,.
i got this and that and this and that lord knows what im doing but im gauging it lol
so i connected and past history and current history was nothing Nadda. never had codes what so ever.
However i do have the power train code P0069
manifold absolute pressure barometeric pressure cooreation. its causing my engie light to turn on PITA .. what do I do ...
Old Nov 6, 2012 | 06:36 PM
bismic's Avatar
bismic
Your Baro, MAP, and EBP should read essentially the same number w/ KOEO. Get the three readings and post them. You should find one of them that is bad.
Old Nov 6, 2012 | 06:39 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Set up those 3 gauges plus EBP volts like this:
Josh
Old Nov 6, 2012 | 06:57 PM
Canadianpowerstroke
why what does that do
Old Nov 6, 2012 | 07:09 PM
Bullitt390's Avatar
Bullitt390
Your map or Baro sensor is off causing the DTC... Set those 2 up along with EBP and check all 3 key-on engine off.
Josh
Old Nov 6, 2012 | 07:10 PM
Canadianpowerstroke
Josh
josh PM me your number I would like to call you i have free long distance. im lost
Old Nov 6, 2012 | 08:48 PM
Bullitt390's Avatar
Bullitt390
It's likely the MAP sensor... but it takes comparing the MAP reading to the BARO and EBP to verify. With all set the kpa they should be all within 3 kpa of each other.
With the MAP sensor you'll check the connector and the rubber line that connects to it.
Josh
Old Nov 6, 2012 | 08:57 PM
Canadianpowerstroke
Josh
hmmmmmmmmmmmmmmm ok still all these acronyms makes a person loose thier mind
Old Nov 6, 2012 | 09:11 PM
Bullitt390's Avatar
Bullitt390
MAP manifold absolute pressure
Baro barometric pressure outside
EBP exhaust brake pressure
Josh
Old Nov 6, 2012 | 09:12 PM
Mich6.0's Avatar
Mich6.0
who makes those gauges?
Old Nov 6, 2012 | 09:16 PM
Canadianpowerstroke
dash boss
Josh you stated that one of them were turned off, how is that
Old Nov 6, 2012 | 09:39 PM
Bullitt390's Avatar
Bullitt390
dash boss
By saying "off" in my earlier reply I meant what I wrote in #7 that the MAP sensor might be bad, the rubber line is cracked or disconnected or the sensor connector is corroded or not connected.
Josh
BuckHammer
16
Oct 2, 2012 06:46 PM
fordtruckrodder
Jul 19, 2012 12:11 PM
NMB2
Mar 14, 2012 02:21 PM
Donny_D
19
May 21, 2009 11:51 PM
william_04_x
Mar 4, 2008 06:42 AM
