HELP!!!
Old Nov 5, 2012 | 03:24 PM
Mark Alligood's Avatar
Mark Alligood
Exclamation HELP!!!
First off, I'm running a 99 F-350 7.3L CC LB. I haven't really done much in the way of mods, it has a chip (TS I believe, it was in it when I got it) 50 cent mod and a custom cold air intake. I had to leave for the weekend and I left the truck at home. I didn't plug it in because it was supposed to be somewhat warm all weekend. I got home early evening and when I went to start it everything looked normal and seemed normal but it wouldn't start. I had the wait to start light as always until after about the third try. The light stopped coming on and the truck will turn over but it doesn't even try to catch and start. It just keeps turning over. I'm not sure if it's related or not but the OD off light on the shifter is on and won't go off. I didn't have a lot of time to trouble shoot this morning, all I did was disconnect the batteries for a little bit and try again. It had been plugged in all night as well so I know it wasn't cold. This is about the worst timing, I still have things to get fixed before the snow gets here. Can anyone help me out with this one?
Old Nov 5, 2012 | 03:34 PM
Franko72's Avatar
Franko72
Molon Labe
Someone with more knowledge will hopefully come along, but if the WTS light isn't coming on I believe your fuel bowl heater may have shorted out.
I also believe your tach wont move while cranking if this is true. Try unplugging your fuel bowl heater (back of the bowl) and check the fuses.
Old Nov 5, 2012 | 03:57 PM
BillyBob69's Avatar
BillyBob69
WHat Frank said....
Check the #30 fuse. If it is blown then unplug the fuel bowl heater, replace the fuse and try again.
Also make sure that your batteries have a MINIMUM of 10.8 volts or... it will crank but not start. This is 10.8 with the key in the ON position and the glow plugs getting power.
Old Nov 5, 2012 | 04:09 PM
Mark Alligood
Thanks guys, looks like a good starting point and I am hoping for a quick easy fix so I can move on to some other things that need to be done. I will report back just in case anyone else wants to know.
Old Nov 5, 2012 | 04:18 PM
howellt39's Avatar
howellt39
If you don't have any tach movement while starting try your spare CPS, assuming you have one of course.
Can you hear the fuel pump going when the key is turned on? Any reason to suspect batteries not providing enough amperage?
Old Nov 5, 2012 | 04:34 PM
howellt39's Avatar
howellt39
If the #30 fuse is blown definitely check the engine harness for rubbing over the DS VC and also at the DS shock mount. That one got me a couple years ago, but I wasn't lucky enough to be parked at home.
If it is that, it'll blow as soon as the key is turned to the on position, but it'll still crank all day.
Old Nov 5, 2012 | 05:57 PM
SkySkiJason's Avatar
SkySkiJason
Like they ^^^ said, first suspect is fuel bowl heater.
This is on the list though, since you said OD lite:
https://www.ford-trucks.com/forums/1...tch-short.html
Old Nov 5, 2012 | 08:33 PM
Mark Alligood
Once again you guys were right on the money, there was a 30 amp fuse blown. I disconnected the fuel bowl heater and replaced the fuse and she fired right up. Thanks again for bailing me out of something that would have probably taken me all day to figure out. This leads me to another question, or two. What would be causing the fuel bowl heater to short and blow this fuse? What kind of negative effects can I look forward to if I leave the heater unplugged?
Old Nov 5, 2012 | 08:39 PM
sand_fiend's Avatar
sand_fiend
A lot of people here just un plug them. Mine did the same and i un plugged mine a long time ago. We don't get cold weather here so it's not a problem for us.
Clay at ruffraff sells them if your in the snow belt.
Sometimes for no reason they just short out.
Old Nov 5, 2012 | 08:45 PM
Franko72's Avatar
Franko72
Molon Labe
When I rebuilt my fuel bowl I eliminated the bowl heater. From what I've read its pretty useless in the first place, but others may argue that.
The only side effect is your " water in fuel " light won't work. I just make sure to drain the.bowl for a few seconds each month ( if I remember)
Tape over the plug to keep it from shorting, and you'll be good to go.
Glad it was a simple fix
Old Nov 5, 2012 | 09:04 PM
BigAlsPSD's Avatar
BigAlsPSD
By eliminate the heater, you mean you removed the element correct?
If so, you can plug it back in, and have the WIF indication still.
Old Nov 5, 2012 | 09:07 PM
Evilinkchris's Avatar
Evilinkchris
Big al I'm looking for a big bad woof? Or something similar but up to date any thoughts. Was told my truck had a bigger turbo than it really does have and want to upgrade any thoughts
Old Nov 5, 2012 | 09:25 PM
Franko72's Avatar
Franko72
Molon Labe
You are correct. I removed the element, and after just checking, I did plug it back in...
I rebuilt three fuel bowls, I guess the one I left unplugged wasn't mine.
Old Nov 5, 2012 | 09:56 PM
BigAlsPSD's Avatar
BigAlsPSD
First off, what does this have to do with fuel bowl heaters/or PCM power and the OP's post.
Secondly, Why? What are your goals, and why not start a thread for many peoples opinions rather than calling myself or anyone else out specifically?
Not trying to be rude, but I'm no expert on the subject except in theory really, not having run a ton of options/setups like others have.
Old Nov 5, 2012 | 10:04 PM
Evilinkchris
Sorry al didn't scroll up or read. Just clicked on an email and went to typing will start new thread I'm no terrorist!
Wallace Mcelroy
Jul 8, 2019 03:54 PM
terry30below
Jan 4, 2009 01:59 PM
swaybar
13
Dec 16, 2008 05:38 PM
Tailspin
Feb 22, 2007 02:17 AM
fhf3723
Nov 23, 2006 01:48 PM
