Rear end ratio
Old Nov 5, 2012 | 08:27 AM
blk92prostreet's Avatar
blk92prostreet
Rear end ratio
Has anyone gone from a 3.73 to a 3.55 and gained what in mpg?
Observed what in rpm drop
2000 PSD CC SB 2WD AUTO 3.7 150K ITP Reg. Rtrn,AFE,Magnaflow3.5dp/4back
foil delete,zoodad mod,hp oilxvr, .450 sonnax mod, DP 80e 80t F5, autometer pyro,boost
Thanks
Tom
Old Nov 5, 2012 | 11:32 AM
SteveH-CO's Avatar
SteveH-CO
You can just do the math as a straight percentage for the RPM, but IMO, that's not enough gearing change to bother. If you bought 1-2 sizes bigger tires, you can turn 3.73 into 3.55. These trucks are a giant physics problem (as far as fuel economy) and a few RPM just won't change it enough to bother. If you went from say, 3.73 to 3.08, then you'd see a significant difference.
Old Nov 5, 2012 | 11:40 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You'll drop 4.8% in RPM. So if you now are at 2000 RPM if you change to 3.55 gears at the same speed you will be turning 1900 RPM. You might be able to gain tenth of a MPG, maybe not.
Old Nov 5, 2012 | 11:52 AM
SARDiverDan's Avatar
SARDiverDan
You can have some benefit but that would depend on the type of driving you do. I run 37” tires with stock 3.73 gears which puts me in the 3.50 range. While I gain a little mileage on the highway, I lose a little in town. Since everywhere I drive from home is highway, it works for me but if I used my truck for mostly towing or in-town driving, I would change the gears. Here is what my RPMs look like at 65mph.<O</O
<O</O
<O></O>
Old Nov 5, 2012 | 12:08 PM
blk92prostreet
Rear end ratio
Thanks for inputs
I guess even if I got 1mpg I would have to drive many miles to pay off those new gears
Then again with taller tires you'll be higher in the air which will cause more drag
Harold Graham
Aug 31, 2017 12:19 PM
chucks wow surf
Feb 28, 2013 09:49 PM
roostercrows
Jun 26, 2012 06:47 AM
ProvBC
Modular V10 (6.8l)
15
Feb 17, 2008 10:51 PM
Norway
May 14, 2004 07:55 PM
