I am currently trying to install an electrical line from my external slip tank fuel pump to the upfitter Auxillary #1. I am wondering where I run the electrical line into the cab??
If Ford has kept the tradition going, your 2012 should have some blunt cut wires coming out of the firewall near the master cylinder. The other end of those wires is under the dash. They are designed to be used by the owner to install wiring, Ford just did the hard part for us.
If you do a search for blunt wires you will find threads on this.
