6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
low coolant temp problem..
Old Nov 3, 2012 | 03:47 PM
fordtruggy's Avatar
fordtruggy
Seems to be one problem after another. Runnin down the highway at 70 and I happen to notice the water temp is only holding steady at about 155 degrees. Usually 195.. pulled over and degas bottle is same lever as always, no leaks. Pulled dip stuck, oil looks normal.. any ideas?
Old Nov 3, 2012 | 03:49 PM
fordtruggy's Avatar
fordtruggy
Also, heater is goin from warm to cool, back and forth..
Old Nov 3, 2012 | 04:31 PM
senix's Avatar
senix
Stuck thermostats?
Old Nov 3, 2012 | 04:42 PM
wp6529's Avatar
wp6529
Sounds like possibly a thermostat issue. If the cooling fan clutch was stuck on you would probably notice the roar.
http://wpnet.us/cooling.pdf
Old Nov 3, 2012 | 04:52 PM
slowmans's Avatar
slowmans
Im guessing stats ar stuck open.
Old Nov 3, 2012 | 10:10 PM
parkland's Avatar
parkland
What is you're EOT?
Old Nov 3, 2012 | 10:30 PM
fordtruggy's Avatar
fordtruggy
I was also thinking the T stats.. I didnt think to check the oil temp.. I stopped at the truck stop and let it sit til it was about 150 degrees and poped both coolant caps. No real preasure at that time and the levels were good. Took off again and the temp held 190-192 the rest of the way.. Does a guy need to run a winter front in cold weather to help these things stay warm maybe?
Old Nov 4, 2012 | 05:44 AM
senix's Avatar
senix
Should not have to if you are on the hwy or certainly not if towing.
Old Nov 4, 2012 | 10:01 AM
parkland's Avatar
parkland
Mine will be at temp within 5 minutes of being locked in OD.
No matter what temp.
Until then, it doesn't work hard enough to warm up when its really cold.
Old Nov 4, 2012 | 11:55 AM
galaxie641's Avatar
galaxie641
Won't need a winter front until about 10°F or less, then it can be a bitch to get warmed up.
Old Nov 4, 2012 | 08:53 PM
fordtruggy's Avatar
fordtruggy
Thanks guys, Gues ill have to search around and try to find a place to order one..
Old Jan 27, 2013 | 07:00 PM
GHeTTo JOe's Avatar
GHeTTo JOe
so looking into winter fronts and have only came across the ford fabric covers, are there any other options. now when towing do they get to warm with the cover on? looking to go snowmobiling in a few weeks and want to make sure the engine is up to temp but not too hot. looks like the fronts also help in preventing freezing up the air filter in snowy conditions which i hope to be driving in.... (need more snow). Now pulling a 4place enclosed trailer on interstate would that be too much for a cover on?> do the fabric covers open part way?
Old Jan 27, 2013 | 10:24 PM
fordtruggy's Avatar
fordtruggy
I bought the ford piece. Never had a problem warming up, even in 50 degree days. Changed both of my thermostats and havent had the low temp problem again. Stays at 200 now. Ive even removed my winter front and now its freezing out side.
orange57
Jul 30, 2016 04:11 AM
Dr G
Jan 10, 2012 09:50 AM
metal_man_xl
1997 - 2003 F150
Dec 16, 2008 09:42 PM
corpsedub
Nov 21, 2004 10:31 PM
rlp
16
Nov 21, 2003 01:06 AM
