Charging Procedure
Old Nov 1, 2012 | 11:24 PM
ol-blu's Avatar
ol-blu
Charging Procedure
Since the batteries are joined together, can a guy hook up the charger to say the drivers battery and have the assumption that the passenger battery will get charged equally??? Or should a guy go out and swap the charger over to the other side a few hours into the charging process???? I got the truck on the charger and would rather not wake up at 3am to swap the alligator clips over to the other battery lol!!! Makes for a PITA to get back to sleep, especially since its cold as all heck around here!!!!!!
Thanks and cheers!!!!!!
Old Nov 2, 2012 | 02:14 AM
bismic's Avatar
bismic
They will both charge evenly when hooking it up to only one battery.
Old Nov 2, 2012 | 11:56 AM
Cowboy65's Avatar
Cowboy65
I recently bought a Battery Minder trickle charger. Follows is some recommended information from their user's manual.
To properly charge or maintain multiple batteries they should all be the same type (gel, flooded or AGM) and condition. It is OK to mix deep cycle and starter. Charge each battery individually before connecting together. Never connect batteries at different states of charge. The charged battery will rapidly transfer energy to the discharged battery possibly causing catastrophic failure.
Old Nov 2, 2012 | 02:56 PM
-Snake-'s Avatar
-Snake-
This is correct.
This is also correct, but the key point is "before connecting them together."
mozzy1234
Jan 15, 2014 01:20 PM
hojolabo
General Automotive Discussion
Oct 21, 2008 07:13 PM
jimbo beam
Electrical Systems/Wiring
16
Dec 31, 2006 07:35 AM
guydiver12
Aug 15, 2005 06:55 PM
Jerrybo66
Aug 19, 2004 08:16 AM
