Sponsored by: Real Truck
Battery ran down
Old Jan 14, 2014 | 10:46 AM
mozzy1234's Avatar
mozzy1234
Battery ran down
Hi
Need to put a battery Maintainer on my 07 f350 which battery do I connect it to? Passenger side or Drivers side, will it charge both and will a 12v charger work not sure on this as Im thinking we have 24v so help would be nice Thanks M
Old Jan 14, 2014 | 01:21 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
2007 with two batteries, am I good in assuming you have a 6.0L?
I put my maintainer on the passenger side battery, it should work to keep both of them maintained installed that way. Just a regular maintainer for a 12V auto battery is what you need, I use a CTEK 3300.
If you actually ran the batteries down, you need to charge and load test them separately, and test the alternator. If one battery fails, you have to replace both at the same time. You should probably get that figured out sooner rather than later, because if your voltages aren't where they should be you could be nuking the FICM by driving it.
Old Jan 14, 2014 | 01:47 PM
tjc transport's Avatar
tjc transport
i ain't rite
12 volt system. the batteries are in parallel ie: positive to positive, negative to negative.. 24 volt would be series, IE: positive to negative.
battery maintainer could go on either battery and still charge both.
on my 88 diesel, it is on the passenger side battery.
my 02 has it hooked to the driver side battery.
mount it where you have a place to hide it and hook it to the closest battery. you will be fine on either side.
Old Jan 14, 2014 | 03:06 PM
Tedster9's Avatar
Tedster9
One thing to keep in mind with parallel, high CCA batteries is a charge is going to take a long time, especially with a low amperage maintainer, maybe a week? Also, It may not be practical or even possible to adequately charge with certain types without a periodic "reboot", (unplug a few seconds) the DelTran battery tender for example automatically switches to float after approx. six hours, whether the battery is fully charged or not.
Batteries used in parallel must be charged together and I would use a charger that is up to the task to save time. A "dumb" charger will work but you have monitor the voltage periodically. It will still take a couple days. You'll want to let them cook for a while (several hours) with moderate gassing at around 14.7 volts or more. THEN you could place them on a maintainer.
Sent from my iPhone using IB AutoGroup
Old Jan 14, 2014 | 04:41 PM
tjc transport
i ain't rite
a 2.5 amp maintainer will charge both batteries to load test good from dead enough to not start the engine overnight.
Old Jan 14, 2014 | 09:07 PM
droldsmorland's Avatar
droldsmorland
Or disconnect the batteries (safer for long term storage of the truck) and put a tender on each
Old Jan 15, 2014 | 01:20 PM
mozzy1234's Avatar
mozzy1234
Smile Battery run down
I thank you all for your replys M
FSJ-EARL
Jul 29, 2012 12:55 PM
Neil64
15
Feb 28, 2010 08:25 PM
blanes
Jan 9, 2008 09:52 PM
jimbo beam
Electrical Systems/Wiring
16
Dec 31, 2006 07:35 AM
guydiver12
Aug 15, 2005 06:55 PM
