Need to get a new rad for the '66 F250 that has the built in trans cooler...aluminum or regular....
Anyone purchased one lately..??...looking for a supplier and a part number...btw, if you're running
a 302, that would be great help. My 302 lower hose exits the water pump to the right side...ie, a
lower right side hose hook-up.
Same 1966/76 F100/350 except 1967/76 with Super Cooling Radiator (it's 4" taller). I've known this for years, and confirmed when...
FTE member (Air Harley), who works for an Escondido autoparts store, went thru old catalogs comparing radiators, cuz his radiator was his-tor-ee.
You punched a hole in your present radiator with a screw driver. So why not take it to a radiator shop and have it repaired? Fixum cost will be waaaay less than a new radiator.
I have always had excellent service out of Modine brand radiators. They last a long time for me. There are surely other good ones but I can only speak for that brand.
