Fuel Economy
#32
#33
Sweet. The next thing is, can the injectors be checked or tested on the truck? I have 200k on them and never been touched. Other than that both fuel pumps and sending units are new. I may go buy a vacuum gauge and check engine vacuum at the manifold while it is running.
#34
#36
I have a 94 F150 4.9 with the E4OD that was just rebuilt last year and 3.55 gears. Now living on the West side of Fort Worth most of my highway driving it between 70 and 80 mph. Speed limit past Abilene is 80 so it is not uncommon to drive at the higher speeds. Most of my driving however is in town.
#37
#38
Oh and my tires are 31" (jus realized I left that out). I did notice one other thin wih this whole issue, my crank case vent hose keeps coming out. Today at lunch I took it all out an blew through it with no trouble. I went ahed and cleaned it with some Berrymans and put it back together I will go by O'Reillys after wor and uy a cheapvcuum gauge to see what my vacuum pressure is. I sincerely dobt the problem is pistons or valves, the truck just runs too god and uses no oil beteen oil changes at 5ooo miles.
#39
Well just to let everyone know what I did. I am the kind of person that chuckles when somethign happens to someone else so on the flip side I like to let folks know when I make a mistake. I have driven this truck for 20 years and just realized that the vent by the oil fill is not the only crank vent. I found my PCV valve. It is now new with a new hose as the old hose was dry rotted. I also replace most of the lines coming from the vacuum block on the intake.
#40
The EEC-IV PCM's aren't that great at trouble-shooting - it's certainly worth checking for codes, but they miss a lot of stuff.
A set of injectors should be easy enough to extract at the junkyard - it's always easier when you don't have to worry about reassembly. Considering their relative low flow-rate, I doubt you can use an alternate donor - it would need to be something rated about 10 pph at the more typically used ~40 PSI. (Stock injectors are 12 pph at 55 PSI)
Have you pulled your PCM to check for leaking capacitors?
#41
I've got a very similar truck...94 F150 with the 300, 3.55LS, but I've got the M5OD.
Dominantly highway, I'll see 18-20mpg if I'm very mindful of my driving and keep it 55-65mph. If I drive mostly around town, it drops to 15mpg, again being easy on her.
Fast highway speeds and towing are going to kill your average if you include them. And if the truck sees mostly around town, how heavy footed are you? And does the tailgating include idling?
#42
#43
I have an '89 F-250 HD Supercab Longbed with 460, ZF-5 speed, and 4.10 gears. When I first got it I was hauling *** all over the place and averaged about 8.0 MPG. After the first few weeks, I started to accelerated more leisurely, coast in neutral as much as possible, and keep it at 65 on the freeway. I saw an improvement to about 11 MPG. After bumping my timing to 12 deg, installing an MSD coil, rotor, and wires, a Flowmaster, and a good tuneup, I now average 12.5 MPG. More than a 50% increase over my original MPG.
cjben
22
03-16-2012 05:54 AM
