Fuel pump driver fail
Old Oct 31, 2012 | 08:49 AM
1bad67sbf's Avatar
1bad67sbf
I went out this morning and truck did not start, took my edge tuner and checked some sensors and seen my AFRP was .5 psi. I figured fuel pump because i could not hear it turn on and did a quick look online and seen people having issues with the driver module for them. i pulled mine and seen it has rusted through the back of it and let moisture in. im hopping that when i get the part this afternoon its all that it needs and im back going.
the reason for the post is to tell people to drop your spare tire and remove the module mounted to the support brace and check it. if its still in good shape paint the back to protect it and put some washers between it and the brace to get an air gap between the two. looks like the new replacements come with that spacer built into the bolts but if you can save a tow bill i would recommend it. it only is two bolts and takes no longer than 15 min.
Old Nov 2, 2012 | 11:08 PM
Papa Tiger's Avatar
Papa Tiger
Can you post some pictures?
Old Nov 3, 2012 | 01:34 PM
Coskid's Avatar
Coskid
Yeah this is an extremely common problem. The new module I think they have a better backing on it to help stop this from happening again. Easy fix and if it ran yesterday and then not today I would bet that's the only issue you have.
Old Nov 3, 2012 | 02:02 PM
1bad67sbf's Avatar
1bad67sbf
Sorry man cant post a pic. My internet is down and all I have is my phone. If you look on YouTube you will see dime videos on it
Old Nov 3, 2012 | 07:14 PM
mercman86's Avatar
mercman86
Thats what happened to mine, except I caught it before it left me stranded. I ordered mine from rock auto. Just about 70 bucks with shipping. Its a doorman and it came with special bolts and bushings to keep it elevated from the frame to prevent any corrosion. It also had a nice paint job.
Old Nov 5, 2012 | 05:24 PM
1bad67sbf's Avatar
1bad67sbf
here you go with the pic, got my internet back today
Old Nov 5, 2012 | 06:08 PM
Papa Tiger's Avatar
Papa Tiger
Kinda looks like a Buffalo Cow chip. LOL
Old Nov 5, 2012 | 07:49 PM
NKENN's Avatar
NKENN
Is this problem more prevalent in areas where they get a lot of snow and put salt on the roads? Should I be concerned if I never drive on salted roads?
THANKS!
Old Nov 5, 2012 | 08:18 PM
1bad67sbf's Avatar
1bad67sbf
i would put the washers on it no matter what. its so easy, lower the spare tire and take two bolts off. i would think you would be fine but ....
Old Nov 5, 2012 | 08:19 PM
1bad67sbf's Avatar
1bad67sbf
yeah man looks like ***** but im glad i did not have to drop the tank and do the fuel pump
Old Nov 7, 2012 | 04:26 PM
Papa Tiger's Avatar
Papa Tiger
I would coat the thing with a good rust preventative. Mine sits up thar in the frame infront of the tank, an I'm thinking lower it and paint it some more too. 2011
Old Nov 7, 2012 | 04:51 PM
1bad67sbf's Avatar
1bad67sbf
cant hurt, doing little things like that can save a PITA moment later on.
Billy Midwood
2004 - 2008 F150
Feb 5, 2017 05:00 PM
C Braves Win
2004 - 2008 F150
Jun 9, 2014 08:31 PM
06_FX4_330
2004 - 2008 F150
Jun 25, 2011 09:58 PM
ron2681
2004 - 2008 F150
Mar 30, 2011 06:37 AM
NYDieselDan
2004 - 2008 F150
May 12, 2008 10:52 PM
