Hello everybody! I just bought an 89' e250 and it's absolutely gorgeous. the power window assembly installed by previous owner(pass side) is broken. the unit is broken at the axle where the motor connects to the arm (sheared).
1st question... are all the assembly's of that era the same (interchangeable)
2nd question... while at the junkyard looking for a replacement, it seemed that the donor assembly's where mounted in a different position on the door?? they where riveted in and appear to be factory. I'm thinking the diff position caused the failure???
3rd question where can I find the rubber and felt window guides???
