Problem with "automatic headlights"
Old Oct 29, 2012 | 12:49 PM
jyarosz's Avatar
jyarosz
I have a 2010 F150 XLT SC. I have the automatic headlight option so I just leave the headlight switch on the auto setting.Lately I noticed during the day the headlights will come on.I know this since the dash lights dim.If I switch the headlights to off the dash lights will get bright again.There is nothing covering the sensor which is in the center of the dash right behind the windshield. Has anyone else had this problem and is there an adjustment for the sensor. It doesn't do it all the time just intermitinly so I hate to take it to the dealer.
Old Oct 29, 2012 | 01:31 PM
SOB Racing's Avatar
SOB Racing
Before going to the dealer I would replace the light sensor and check wiring and connection. Sensors of all types go south all the time.
Old Oct 29, 2012 | 02:24 PM
ChargersFanInCO's Avatar
ChargersFanInCO
Are you using your wipers in the delay or on mode? If you are, they will come on. I ask because you're in Michigan...gloomy time of the year.
Old Oct 30, 2012 | 07:06 AM
Going_Going_Gone's Avatar
Going_Going_Gone
From what I understand, the sensor on the dash is a two-function unit. The left half controls the headlights on/off and the right adjusts the dash illumination to outside light conditions. On my truck I've noticed that it is usually at sunup/sundown (and driving into the sun) that the headlights will be 'off' but the dash stays dim so you can't see the gauges very well. I've heard the the fix is to cover the right side of the dash sensor with black tape.
Old Oct 30, 2012 | 07:40 AM
jyarosz's Avatar
jyarosz
Thanks,I'll check that out.
Aftrmidnite
2015 - 2020 F150
23
Dec 16, 2020 09:27 AM
BIDIL
Nov 21, 2016 08:55 AM
wbialik
2009 - 2014 F150
Oct 2, 2010 08:59 PM
maddogcycles
Mar 24, 2010 09:26 AM
Downriver Thunder
Nov 19, 2009 09:23 AM
