Sponsored by: Real Truck
Dim climate controls
Old Nov 18, 2009 | 07:34 AM
Downriver Thunder's Avatar
Downriver Thunder
I was noticing this morning on my way into work that my climate controls look very dim. The dash light brightness is all the way up but they still look dim. Any ideas?
Old Nov 18, 2009 | 11:27 AM
bpounds's Avatar
bpounds
Were your headlights on? Something covering the sunload sensor?
Old Nov 18, 2009 | 11:37 AM
Downriver Thunder
Headlights were on. This was 5:30am, nothing over sensor. It just seams the climate controls, (manual), were dimmer than the rest of the dash.
Old Nov 18, 2009 | 07:50 PM
dtingle89's Avatar
dtingle89
yeah ive got the same problem, also i have to turn the dial with the numbers for the force of air all the way then back to get it to light up. i wish there was a bulb or something to replace
Old Nov 18, 2009 | 08:46 PM
johnnysF350's Avatar
johnnysF350
There are bulbs in there, 3 or 4 I think. You have to pull the climate control module out, 4 8mm screws. There are small black caps on the back twist them out and the bulb pulls out of them. Now you can spend about 4 bucks a piece to buy them from Ford with a new cap or just go to the auto parts store and buy the bulbs. Pull the old bulbs out of the cap and insert the new one. You probably only have one out but change them all while your in there. This is common. Just dont touch the bulb with your skin as you will transfer oil onto it which can shorten its life
Old Nov 19, 2009 | 09:23 AM
Downriver Thunder
We stock almost the whole line of bulbs from wagner here at work. I just have to figure out the number of them.
tjmcb
Jan 10, 2014 11:22 PM
MarkStarr
Feb 12, 2013 04:05 PM
BlackstarF250
Apr 2, 2011 03:47 PM
TSCOPE50
2004 - 2008 F150
Aug 4, 2007 03:28 PM
Beast12
Electrical Systems/Wiring
May 16, 2004 04:38 PM
