Sponsored by: Real Truck
Front leaf springs
Old Nov 2, 2012 | 12:06 PM
SuperDutyScaler's Avatar
SuperDutyScaler
also Ford had recalls on their front leaf springs because the cheap plastic antisqueak pads wore out within a year and ford came out with a newer better design, so YES thousands of Ford trucks had this squeak thats why Ford made the recall and newer parts for their crap design
Old Nov 2, 2012 | 12:09 PM
SuperDutyScaler
and yes procomp 22210 flex wwaayy better then stock!
Old Nov 2, 2012 | 12:13 PM
SuperDutyScaler
heres the 22210 stance after two and a half years on my F350
Old Nov 2, 2012 | 12:17 PM
king-david's Avatar
king-david
You convinced me! Haha
Old Nov 2, 2012 | 04:07 PM
Hotpocket's Avatar
Hotpocket
like he said...it is like the truck went from a stiff dump truck ride to an f150 ride...and those are some awesome flexing pics!
Old Nov 3, 2012 | 03:37 PM
SuperDutyScaler
thanks! its the most sideways down the hill i could have gotten. Dumb LS wouldnt work of course and i couldnt get it stuffed up any further!
Old Nov 3, 2012 | 03:41 PM
SuperDutyScaler
i read on here that ProComp springs dont ride good but thats using their crappy shocks, all i know is these "diesel" springs ride like a dream on my 5.4! My dads 2000 diesel has superlift level springs that again sagged but SL wont warrenty them because they replaced them once already so his gonna order the 2210 for his diesel so ill do a write up and post about how they hold up to a big boy diesel motor
Old Nov 3, 2012 | 04:48 PM
golfmedik's Avatar
golfmedik
I just read through the thread. YES, I've bought springs through SDTruckSprings and they were cheaper than getting through my dealer, even though my dealer had some good prices. I ordered X/C codes for my Excursion. X=Snow plow prep for the fronts and C codes which are 2003 dually w/o overloads for the rear. Do not let one persons opinion sway you. Go over to the Excursion forum and look at how many put super duty springs on the Excursion to make it ride and drive MUCH better than the stock ones. As for pickups, SDTrucksprings have the same spring rates the dealer has. I have nothing but good things about them. My X does not ride rough at all. True, some people want and very soft ride, but that is a trade off with body roll most of the time. The truck should hold it's height if you replace the original spring with the same rate spring. If you want a slightly stiffer spring, they have that too..True, shipping is expensive from them due to having to come freight. If you are close to a dealer that can give you a good deal, you might come out better there. Also, give Tousley a chance to see waht they can do.
Old Nov 3, 2012 | 05:21 PM
EXv10's Avatar
EXv10
Not really, they sit lower and the sway bar takes care of that. Mine doesn't roll at all and if it did there is always the rear bar option. I don't know what all the too doo is about different springs. They are basically all the same but some are stiffer than others.
Old Nov 3, 2012 | 05:24 PM
king-david's Avatar
king-david
Maybe Tousely would be willing to do some sort of group buy on X codes?
Old Nov 3, 2012 | 07:45 PM
EXv10's Avatar
EXv10
Then you would have a whole group of ex's with the nose in the air and riding like an empty dump truck.
Old Nov 3, 2012 | 07:51 PM
foster2004f250's Avatar
foster2004f250
I think that scalers set up is the way to go!! It looks badass! But I just need up going with sdtrucksprings x codes! I just put a set of 305/70/16 duratracs on and $$ is a little tight, so this is going to have to do!! Thanks for all the input!!
peenhead
Apr 15, 2025 05:05 AM
kras498
General Automotive Discussion
Mar 12, 2015 11:43 PM
twinpeaks
May 30, 2012 06:01 PM
James Johnson
Nov 15, 1999 08:25 PM
