They will. What has happened to me several times is that small cracks will appear that eventually leads to leafs falling off. Usually you can spot a difference in ride height as they fatigue.
I believe a good way to tell is if your rear is sagging without any load in the back. When I was trying to decide if mine were ready to go, I came across a pretty good article that explains this. Here is a picture to help.
So, what are shackles for? If the article is to be believed then you should automatically replace the springs once they start to go weak. Yet, they sell spring shackles... Isn't this basically the same as "repairing" worn out springs?
Not really, the shackles let the springs move with the different loads.
You can have good shackles and weak springs.
You can get an idea if one side or the other is weak by getting a couple of people, (the larger the better) and stand on one side of truck. Which ever side drop farther down is the weak side.
If both sides hit your rubber stops without a great amount of weight, you probably should replace both sides.
Note: This is presuming that the shocks are ok or equal and that you have not noticed any cracked or broken leafs.
at 150k unless the truck has spent alot of time loaded or being beaten off road they should be ok aside from possible broken leafs.
a good example is an '88 F250 Diesel my dad bought... a good part of its life it had an 8'x10' steel deck on the back, empty the truck was a few hundred pounds from GVW. eventually we put a box on it but the springs are so beat that the other truck ('90 F250 with a 460) can actually pack far more weight. the same 11' Camper that pretty much puts the 1 ton on its bump stops only drops the 3/4 ton 2 or 3"(truck sits just below level ride height)
