Locking Fuel Cap
Old Nov 10, 2012 | 10:26 AM
majkthreads's Avatar
majkthreads
Originally Posted by Rick Cargo
I really like my AMI locking door. I also have a locking Stant cap.
I picked up the same one but had it painted to match the truck.
Old Nov 11, 2012 | 06:45 AM
Adventure Rider's Avatar
Adventure Rider
My Install or things to be aware of
Starting with the end result
Up close
The product arrived well packed
Front View
Back View
Packaging Content - single piece of paper is the woeful instructions
Hardware
The issues/comments I had
- insructions were not well defined and an additional statment or exploded view of hardware sequencing would have gone a long way
- Drilling was required as stated as a possible option, and the 3/16" drill was not sufficient, this was due to that the posts inserted into the back of the frame house were not perpendicular to the frame base - they pointed slightly in - I did not notice this until it was too late and reamed out the holes a little more to get the piece to fit
- the other major issue was the two post on the right side (towards the back of the truck) - due to the design of the fill well with slopes in it very difficult to tighten the nut and it was impossible to fit the provided washers on the post studs - I needed to get smaller washers for these two.
- the last issue which I can deal with but should not be there for the cost of this item is that when the door is closed and locked it is not tight against the latch and moves back and forth about an 1/8 of an inch
Overall 3 out of 5 stars, a good product that can be made much better with a little more thought and attention to detail
Old Nov 11, 2012 | 07:15 AM
Hdslider's Avatar
Hdslider
Adventure. You can tweak the peice the latch catches and tighten it up. Plus the lock arm may need a liittle tweak put to it. Ive got mine where you acually can feel it hitting. Before you lock it.stays nice and tight.
Old Nov 11, 2012 | 07:34 AM
Adventure Rider
Thanks HD will try that
Old Feb 13, 2018 | 11:19 AM
Larrymac52's Avatar
Larrymac52
Originally Posted by Adventure Rider
this one says it does not fit my 2017 F350?
any updates or news on after market locking fuel cap for the 6.7? Also the DEF cap as well?
Old Feb 13, 2018 | 11:33 AM
Just Strokin's Avatar
Just Strokin
Did you read the comments about the cap?
A. HoustonTop Contributor: Photography
5.0 out of 5 starsWorks Great On 2017 F350
December 29, 2017
Verified Purchase
I've used Stant fuel caps for years and this cap works perfectly on my 2017 Ford F350 dually Crew Cab. Tip: you do NOT remove the cap with the key. You turn the key (just a little), then twist the cap to remove it. If you try to remove the cap with the key alone, it probably will break after a while. These caps have always served me well, and this one seems to follow that trend. Very satisfied.
There is no update on the DEF locking cap. Still not one available.
Old May 25, 2024 | 01:56 AM
FX4 Jezebel's Avatar
FX4 Jezebel
Lightbulb MIA Locking DEF Cap Manufacturers... HELLO!
Why aren't all of the locking DEF cap manufacturers capitalizing on massive revenue with this simple, yet sorely needed item?
Maybe it's time to find one, and have a South Korean manufacturer produce one-million with defensive improvements while honoring patent laws.
Sadly, those $250 aftermarket thin alloy combo diesel and DEF kits have a very thin and weak three-finger composite retention system that is easily defeated.
I bought a <$10 OE-style black locking 2018 Fx4 diesel cap that accepts the key both ways, and allows
locking and key removal with cap off for quick locked spin-on without wad of keys inserted.
You can leave the key wad in if you're worried about leaving the cap behind.
Old May 25, 2024 | 02:03 AM
FX4 Jezebel
Thumbs up Aesthetically Appealing On Your Unit!
Looks great with those exposed fender-flare fasteners!
Definitely looks odd and gaudy on trucks without the exposed flare fasteners.
Hopefully, they'll eventually legalize instantly incinerating high-voltage systems to fry thieves and vandals.
mhoefer
Feb 12, 2017 06:53 PM
ironbender
6.7L Power Stroke Diesel
Feb 28, 2016 07:36 AM
jsw0767
Oct 14, 2014 06:06 AM
rgraham52
Feb 8, 2012 03:26 PM
Hayman4353
Aftermarket Products
Nov 17, 2006 02:01 PM
