Read through his first link up above. That is the Torque app forum.
Otherwise go to a screen with gauges on it and press your screen in a blank spot and hold it until a menu pops up and says add a display. Choose what you want it to look like and size, then choose a PID. Hope that is it.
I thought you had to plug in forumulas and do hard math and write code.
My BT adapter is held up in due to Sandy so I've not had Torque hooked up to the truck yet.
Thanks for clearing that up for me.
Nope, other people out there have done the hard work for you as far as the formulas and PID numbers go. All you need to do is type the information in and then set up the gauge to read it.
