Diagnostic tools
Old Oct 29, 2012 | 07:52 PM
Yahiko's Avatar
Yahiko
Ok I have one here that I will be selling soon because I just upgraded.
I have a Snap-on MT-2500 with the programable cartridges that cover up
to 2006. It's also know as the red brick. It does a very good job with codes
and even will clear some that the SGII won't. It will talk with the
can and non-can buss systems and can tell you want P000 is with out having
to look it up most times. You can find them on Ebay.
One thing about AE is you need to get a laptop and the Panasonic Tough Book
would be my first pick do to the fact it is a hard service laptop with armor.
You can stick it under the seat and not worry about someone sitting too
hard on it.
Sean
Old Oct 29, 2012 | 07:53 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Originally Posted by the_auto_tech
The only thing I'm trying to figure out is what things you guys are monitoring. I'm using the Torque app on my Android phone. I've got ECT, trans temp, and boost at the moment. I'm trying to figure out how to get EOT. That leaves me two spaces on the screen yet for gauges. What else should I be monitoring?
All of them
Old Oct 29, 2012 | 08:20 PM
BLADE35's Avatar
BLADE35
Originally Posted by Bullitt390
My truck doesn't throw any codes...
Josh
You just Cursed/Jinksed your Truck Josh LOL
Old Oct 29, 2012 | 08:25 PM
BLADE35's Avatar
BLADE35
Originally Posted by bismic
One key is if it is good at reading transmission codes. That is a knock-out for many cheaper code readers.
Great Point^^^
And to add to it I am thinking ABS/Air Bag Codes
Old Oct 29, 2012 | 08:27 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Did you forget that you have a fleet of 25 6.0L trucks .............. If you haven't been using it on any of them, then I don't see how you can brag on its abilities with the Ford OBDII w/ CAN platform.
As far as a Mercedes goes - well thats good but it doesn't add any assurance regarding the 6.0L.
I am not doubting it is a good tool, but you seem a little biased to your neighbors product. You have done a good job posting the PIDs it reads. That has been convincing and helpful. Just do that w/ the DTC's it reads as you experience them (with other peoples trucks of course .....).
I haven't worked for that company in quite a while. And from 2003-2009 only 1 truck out of over 25 was a red-headed step child.
I am also one that doesn't go around drinking the kool-aid.
Josh
Old Oct 29, 2012 | 08:33 PM
Bullitt390's Avatar
Bullitt390
That's why I have been putting off an EGR delete. I know once I start messing with things it will be all downhill from there.
Either throwing codes or wanting to buy more parts.
Josh
Old Oct 29, 2012 | 08:37 PM
FordBlueHeart's Avatar
FordBlueHeart
For those of you wondering where the Torque PID lists are:
Forums — » Torque OBD ECU Scanner » Torque Discussion / Ideas » Ford 6.0L Diesel Extended PIDSTorque
Also, this is a helpful site too:
Write Up: Monitoring the 6.0L PSD. - Ford Powerstroke Diesel Forum
I'm thinking that my main page will consist of:
Coolant temp
Oil temp
Trans temp
FICM Main Power
Injection Control Pressure
Battery voltage
I'm thinking of making the 2nd page this:
Engine load
Gear with TCL
Injector pulse width
Turbo boost
Fan
IPR
Thanks for all the info. I am also using Torque for now. I placed my 6 most important PIDs on a single page, placing them on the outer edges and then placed a few smaller digital readouts centered between them. All I need to do is glance at them and I know if everything is ok.
I still have plenty of questions about its accuracy and proper values that I should see. I plan on reading your provided links next.
Old Oct 29, 2012 | 08:43 PM
Bullitt390's Avatar
Bullitt390
What is the refresh rates on the Torque App? Pretty much instant or delayed like SG2?
Josh
Old Oct 29, 2012 | 08:58 PM
FordBlueHeart
Josh
I'm not sure on the refresh rate for the SGII, but Torque is less than a second I would guess. I think it is quick enough, but I don't have anything to compare it to. Now I will pay attention and probably be disappointed. Thanks
Old Oct 29, 2012 | 09:02 PM
Bullitt390's Avatar
Bullitt390
An etch-a-sketch has better refresh rates than SG2 LOL
I'm sure Torque is fine.
Josh
Old Oct 29, 2012 | 09:17 PM
FordBlueHeart
Etch a sketch is awesome! It's slow? LOL
Old Oct 29, 2012 | 10:12 PM
daddykitty's Avatar
daddykitty
i would like a bank account pid to watch
Old Oct 29, 2012 | 10:16 PM
  #28
Bullitt390's Avatar
Bullitt390
Just call it the WIFE Parameter
Josh
Old Oct 29, 2012 | 10:18 PM
  #29
the_auto_tech's Avatar
the_auto_tech
Josh
I would say a second or less. The numbers seem to move consistently and I don't see any drop-offs. This is with my cheap Chinese Bluetooth OBD-II dongle as well. So far I'm loving the app. It does a lot of super handy things.
Old Oct 29, 2012 | 10:55 PM
  #30
daddykitty's Avatar
daddykitty
Josh
i was thinking more like WTF
