Driveshaft seal????
Old Oct 28, 2012 | 08:40 PM
Eallend7's Avatar
Eallend7
Driveshaft seal????
Well i'm changing the FRONT u joint on my REAR driveshaft.
I have an '86 f250 4x4 and i know this driveshaft has somretraction in it where i guess it's two pieces and the front can slide into the back part somewhat in case of binding or whatever, but the back of my transfer cause where the u joint is located is also somewhat blackened like it's been splattered by grease or fluid, should there be a seal around the gear shown? It may be there but has just failed? Orrrr am i just completely wrong? P.s is there a better alternative to this factory driveshaft? maybe a completely solid one without the plunging action???? i just feel like that would be a weak link, anyhthing with moving parts will break...
And yes i pulled the yolk out some so that yall can see...
Old Oct 29, 2012 | 05:17 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Ok, from what i can tell, the seal is present in the end of the t-case. The black sludge looking stuff is from the seal letting a very small amount get by (weeping) and then road grime collects to the oil. This is pretty common. However i would say the t-case is low on fluid, as none spilled out when you removed the yoke. You will notice a breather tube on the transfer case, ensure that tube and breather is clear and working so the case is not pressurizing and pushing the oil past the seal.
Your driveshaft is two piece because it is too long to be one piece. After a certain length (for instance .082" x3.5" tubing is only good to 69") the tube will vibrate of its own accord and crack. There is nothing wrong with the factory driveline setup. Just make sure you grease it and that the support bushing is good and you wont break it i promise.
Old Oct 29, 2012 | 05:42 PM
hookedondiesel's Avatar
hookedondiesel
That doesn't look bad to me,
is your truck a King Cab, or just a regular box.
Pressure wash the crap out of it...lol
Then you'll see if it's leaking, but it doesn't look like it to me.
Old Oct 29, 2012 | 05:53 PM
Eallend7's Avatar
Eallend7
standard cab, and ill check the fluid, if it's low it's probably been that way for a while :x
Edit: hey hairybox what do you mean grease the driveshaft and make sure the support bearing is good? wheres the support bearing and what do you mean by grease it?
Old Oct 29, 2012 | 08:13 PM
hairyboxnoogle
Where the slip is in the driveshaft, where the 2 pieces come together, they slide, there should be a bearing there to grease the splines on the slip-shaft. The support bushing (called something else but cant remember) Is a rubber "bushing" that the driveline sits in that supports the middle at the slip-shaft. Sometimes these get brittle and break, crack, fall apart etc, ive seen them smacked by stuff and bent over too. Not sure if theres a bearing in there or not.
Old Oct 29, 2012 | 08:32 PM
Eallend7's Avatar
Eallend7
mine just has a rubber housing over the slip part, with some sort of clamps on them, idk if they are supposed to be removeable or not so i didn't mess with them
riverguideguy
Jun 30, 2013 06:45 PM
ssrider
2004 - 2008 F150
Dec 8, 2011 10:35 AM
powrstrkr
Bronco II
Mar 23, 2007 05:37 AM
95f150
May 15, 2005 08:55 AM
psycocrazy
1983 - 2012 Ranger & B-Series
Apr 8, 2004 10:49 AM
