Guess what? Another no-start thread
Old Oct 30, 2012 | 08:56 PM
dlibson's Avatar
dlibson
Originally Posted by cheezit
not exactly true, however this is the case about 90% of the time. i have seen more then one set leak when cold and seal when hot. kinda makes you wonder sometimes.
Well, I've seen that too. Heat can expand stuff and help it seal too...
Old Oct 30, 2012 | 08:57 PM
BLADE35's Avatar
BLADE35
Great point^^^ Cheezit things do Expand and contract Hot & Cold & Leak and Seal
IIRC the original complaint was Trouble with Hot Starts and Cold Starts OK
Hope when he does the next test he will get EOT to 190* maybe he did this time IDK
Old Oct 30, 2012 | 09:01 PM
BLADE35's Avatar
BLADE35
And it seams like there is No Ryhme or Reason to it either
one leaks hot the next will leak Cold LOL
Old Oct 30, 2012 | 09:49 PM
blain stumpf's Avatar
blain stumpf
Trailering
Drove it hard and pulled it directly intop my shop. We had it plugged in and reading in about 3 minutes. No time to cool down. The hot start problem was happening 10-15 minutess after turning it off. So we were in the window.
Now here is the weird part. Ever since giving it the 30% command it has started every time. I've drove it just like I usually do, started at least 10 times today after that. No hesitation.
Where do I go from here?
Blain
Old Oct 30, 2012 | 09:56 PM
blain stumpf
Trailering
Originally Posted by BLADE35
Your ICP sensor is BAD
The IPR is adjusted from the ICP reading
so might be the ICP throwing the Bad signal
The ICP values were following the pressure consistantly. .25v @ 0 PSI up to 1.0+v at (going by memory here) 900 PSI.
What other parameters does the IPR use?
Blain
Old Oct 30, 2012 | 10:09 PM
BLADE35's Avatar
BLADE35
You need to post values at
KOEO
Low Idel truck Idel on it own
High Idel 2500 RPM
Its going to throw a wrench into the gears if you Command IPR
You Could be Commanding the IPR% High Enough top Cover for a Leak with me???
Old Jan 25, 2013 | 09:31 PM
blain stumpf
Trailering
Just in case anyone is subscribed to the thread or is otherwise interested in the results here you go;
3 months of dependable starts hot and cold. Then one day, Gotcha! Hot no-start. Let it cool for about an hour and fired right off. Got it back to my shop and we rolled the dice on the IPR. No luck. While at the dealer buying a new IPR one of the Powerstroke mechanics gave me the word on the standpipe plugs. At $20 each I figured what the h__ and bought a pair. Good thing 'cause it was not the IPR. Can anyone see where this is going? Yes, torn "O" ring on the right side plug. About 5 hours of labor and $40 of upgraded plugs and we are fixed.
Moral of the story; buy a Chevy, no sorry, replace the plugs with the upgrade they will probably fail sooner or later.
Blain
Old Jan 25, 2013 | 09:47 PM
BLADE35's Avatar
BLADE35
thanks for posting the outcome reps Given
Old Jan 25, 2013 | 09:54 PM
bismic's Avatar
bismic
I think Benny mentioned them in post #2. Anyway - glad it is resolved.
Old Jan 25, 2013 | 10:06 PM
m-chan68's Avatar
m-chan68
Originally Posted by m-chan68
Let's chalk this up to another 6.0L that will likely need a set of dummy rail plugs and an STC and be good to go after that.
Isn't that what I said in post #3 of this thread?
Old Jan 25, 2013 | 10:58 PM
BLADE35's Avatar
BLADE35
Yes SIR^^^^^^
Its one of those things thats a Given (Or its been Talked about alot on here!!)
I get the Feeling a Updated Standpipe got Left Out!! How you Guys Betting on that??? LOL
Old Jan 26, 2013 | 08:44 AM
cheezit's Avatar
cheezit
and again in post 15
Headviking
Sep 15, 2015 04:51 PM
mtnxtreme800
Sep 21, 2014 08:16 AM
f150crewcab
May 23, 2014 07:12 PM
tonefordays
Nov 7, 2012 07:47 AM
NYC F-350
Feb 27, 2011 10:25 PM
