Trans issues
Old Oct 27, 2012 | 01:10 AM
smokersteve's Avatar
smokersteve
Trans issues
Going in between D and R is slow, and 2-3 sucks, especially gong from 3 down to 2.... and 3-4 is weak.
I have IDP tunes. Im on top of maintenance.
If I remember correctly it is the solenoids that will need replacing.
What should I do to the trans?
Thank you.
Old Oct 27, 2012 | 07:14 AM
Maxium4x4's Avatar
Maxium4x4
What does it do if you flash the truck back to stock settings, drive it, then reload the tunes?
Old Oct 27, 2012 | 10:40 AM
smokersteve
I thoght about that last night. I will try that thanks.
Old Oct 27, 2012 | 01:22 PM
Maxium4x4's Avatar
Maxium4x4
When a problems surfaces, always remove any tuner first then see what you have. Sometimes, the programming will get a little lost, the reflash will set things straight again and remove the bad habit it acquired.
Old Oct 27, 2012 | 06:55 PM
smokersteve
That sucks. You would think the quality would be as good as OEM when it comes to this kind of sensitivity.
Thanks for the advice. I will do that tomorrow and give it 2 weeks.
Txforever88
Jan 29, 2016 11:20 AM
4EXTRDR
Nov 3, 2011 09:02 AM
Texas450
6.4L Power Stroke Diesel
Dec 16, 2010 05:04 AM
dmueller71
Jul 25, 2008 04:36 PM
messeswithtrux
Apr 14, 2008 05:31 AM
