A long time hot rod builder friend of mine recently brought up the issue of how heavy are the cabs on our trucks, and after some snooping through various sources, it became very clear that few if any builders ever weigh just the cabs. So ... I'm posting this question for all to ponder, and hopefully someone will have the answers. For the 48 - 52 F series trucks, the cabs for the f1 through F8 conventional models should all basically be the same weight. The COE versions will likely be different .. they have more bracing on them, but less door area.
The other rigs we are trying to figure out are the cab weights for the 40 conventionals, and the COE cabs as well.
Is that a bare cab? with doors? with doors with glass? I'd say a bare cab is under 200. I was surprised last week when I took my running 54 F100 across the scales. Most everything on it except cab interior upholstery and a bed. 2500 front axle, 3700 total, 1200 rear axle. I'm going to avoid driving it in the rain until I get a bed in it and maybe a spare tire hanger and spare under the bed behind the rear axle.
That's the highest weight I've heard for an F-100, especially without the bed! What engine, etc., do you have? Were these certified scales? Usually more like 3200 - 3300 with everything.
I agree with Ross. Unless you're running a big block with a C6 and some hefty chassis mods, I can't see 3700 without a bed. Those numbers are highly suspect. I'd be for getting a second opinion.
The best way to weigh your truck is to have both axles on the scale. If you weigh the front and rear axle separately you will get a higher number because of the lever effect. Same idea as weighing a log on each end rather than the whole log.
An F100 weighs close to 4000 # complete. My little Solstice weighs 2875# with empty tank and no driver. That and the frontal area is why you get low gas mileage.
Mervy, try it, you will get the exact same weight if you add the front axle and rear axle weights or weigh the whole vehicle. I've corner weighed a lot of vehicles using 4 pad scales and platform scales. If you weigh it with 4 pads and add the 4 wheel weights you will get the total weight as well. There is no "lever effect" error. Sorry, pure physics.
OK, let's look at the physics: you have a weight (the truck). if it was balanced on one point, and a scale placed under that point, it would read the total weight. Add a second point under the weight, now the total weight is supported by the two points, it doesn't matter where those two points are located under the weight. If you put a scale under each point you would read what portion of the weight each point supported, but both are supporting the total weight so adding the two scale readings will equal the total weight. Put 4 points of support and 4 scales under the weight and the total of the 4 will equal the total weight. It doesn't matter what proportion each is supporting, you can move those supports anyplace you want, the total weight supported is still the same.
Unless the weighing point (scale) is at a considerably different height. Then the center of gravity can shift relative to the scale and the pavement. That's why truck scales are not built on elevated platforms. Think of it at an extreme. Tailgate dragging on the pavement and front wheels barely touching the scales. Of course, that is an extreme. However, that's why a calibrated scale is right at pavement height.
